It is currently Sun May 03, 2026 1:26 am
PostPosted: Wed Jan 06, 2010 9:40 am
I have dual baby delortos on it now and I'm getting tired of screwing the carbs and the way my cage is set up I have knocked off the air cleaners in the woods. I'm looking for idea's on what carb to get . I would probley trade the dual for a good carb setup????
PostPosted: Wed Jan 06, 2010 10:28 am
weber progressive is my opinion !
PostPosted: Wed Jan 06, 2010 10:57 am
That is what I was thinking, what is the going prices on them ??? THANKS
PostPosted: Wed Jan 06, 2010 1:22 pm
i would post a wtb add for that carb and see what you can come up with would save you alot of money if you can find a used rebuildable or a running one !
PostPosted: Wed Jan 06, 2010 3:22 pm
OK I will try that THANKS
PostPosted: Wed Jan 06, 2010 6:00 pm
if u allready got the carb use it,,one of the baby dells on a stock intake,i think u can make one work on a stock intake
PostPosted: Thu Jan 07, 2010 4:08 pm
What size is to big I have seen 40's in a single set up and are the empi carbs any good??? Just trying to get all my dicks in a row before I buy one THANKS for all the info
PostPosted: Thu Jan 07, 2010 5:37 pm
Rule of thumb for selecting the right carb(s) for your motor. Smaller Venturi = better low end torque while sacrificing top end. Larger venturi = higher top end while sacrificing low end torque. Your 1600 does not have a high top end to begin so low end torque is what you should be looking for, ie; smaller carb(s).
PostPosted: Thu Jan 07, 2010 5:44 pm
ive had a solex but now i got the weber 2 barrel i like both of them
Brandon
PostPosted: Thu Jan 07, 2010 5:54 pm
Only if your a patient tuner.
PostPosted: Fri Jan 08, 2010 9:14 am
I was just thinking cause my brother had a bigger delorto (38 or 40)on his buggy and all he ahd done to it was 87?? pistons and a cam and it ran good
PostPosted: Fri Jan 08, 2010 3:04 pm
u can put a 40 or 44 weber,dont get empi heard about to many problems,but when u put a weber on it be ready for somebody to jet it for you,it could be a pain in the ass,and it could run good the first time
PostPosted: Sun Jan 10, 2010 1:19 pm
Are the jets hard to get too in a webber carb??? Or are they hard to get jets for??
PostPosted: Sun Jan 10, 2010 10:18 pm
there not hard to get to,there not hard to get,,,,get a single weberto run the way it suppose to is not easy
PostPosted: Sun Feb 14, 2010 10:32 am
Does any body make a adapter or intake manifold that will let me use a automotive/holley 2 barrel carb on a vw ???? I have seen the 4 barrel manifolds but no 2barrel ones???
PostPosted: Sun Feb 14, 2010 10:59 am
You can use a 4-barrel manifold, most 4-barrel carbs will bolt on where the 2 barrel ones go on, its just the difference on the v-8 manifolds, some got 2 holes, some got four holes, and some got one big hole and that's what the fourplay is like. I started out with the fourplay manifold and 2-barrel 550 holley and it runs great, but no good off-road, I could never get the thing to quit flooding out no matter what....so I switched to 4-barrel, still the same problem, just more power on level ground.
PostPosted: Sun Feb 14, 2010 11:06 am
Re-jetting Weber carbs is fairly easy......it just takes time and patience. The Jets are easy to find for these webers.
I get all of mine from CB Performance...http://www.cbperformance.com/category.asp?CategoryID=6
or Pegaus Auto Racing....http://www.pegasusautoracing.com/group. ... WEBERIDFPJ
PostPosted: Sun Feb 14, 2010 12:52 pm
does fourplay make a 2barrel carb manifold i have a 2barrel motorcraft carb thet works good offroad that I would like to try that is why I'm . THANKS for the fast responce :D Does fourplay have a web site????
PostPosted: Sun Feb 14, 2010 3:22 pm
Nope, if the carb that you want to run will not work on the 4-play, I bought a Holley 550 2 barrel and it bolted right on the 4-play manifold and the carb that you have, I dunno. Johnny's four-play does not have a website, I don't have a phone number for the place though.
PostPosted: Tue Feb 16, 2010 11:05 pm
The stock carb is one of the best carbs for a stock 1600. Adding dual carbs to a stock 1600 adds a whopping 5 hp while 10% it is not much gain for the money spent. Splitting the case and adding an Engle VZ 14 cam, along with a single Zenith or Weber will really wake it up. Some porting will help but is not needed. I've never tried a Holley Off road two barrel carb but it should work, the only disadvantage I can think of is not being able to change venturi size. Down the road a 76x90.5 (1955) with a VZ 14 cam, heads like Tims Stage Two heads and a single 40 Weber makes a killer bullet proof small engine. Same engine in 69x94 also runs great and is easier to build. http://www.aircooled.net has a good Weber IDF carburator tech section.
