It is currently Mon May 04, 2026 4:10 pm
 Post subject: DID IT MESS UP?
PostPosted: Thu Aug 13, 2009 8:18 pm
let out on the clutch to fast i think and it wont go in any gears? is my trans screwed up now? i took my left axle out and when you start it up where the cv joint bolts to its spinning still? or could it be the clutch? if its the trans would i be better off lettin someone rebuild it for me or just get a diffrent one? and if it does need rebuilt what would be the best way to take it out?
Brandon
 Post subject: Re: DID IT MESS UP?
PostPosted: Thu Aug 13, 2009 10:19 pm
ive noticed it has been leaking some cause it was building up on the cv bolts
Brandon
PostPosted: Thu Aug 13, 2009 10:38 pm
did the cv break?
PostPosted: Thu Aug 13, 2009 10:55 pm
nope cv didnt brake
Brandon
PostPosted: Thu Aug 13, 2009 11:02 pm
Pull the drain plug and see if there are any metal chunks on the magnet. You might have blown the diff or r&p. What trans? Does it grind or make any funny noises when in gear? I have seen a few clutches explode when dumping the clutch.
PostPosted: Thu Aug 13, 2009 11:06 pm
im running a 3 rib its a 73 or 74 is what the guy i got it off of told me its hooked to a 1600cc motor and nope no grinding
Brandon
PostPosted: Thu Aug 13, 2009 11:08 pm
Does it have the acorn nuts on the sides by the cv flanges?
PostPosted: Thu Aug 13, 2009 11:09 pm
what are you sayin acorn nut? its a side shift i all i know are you talking about the 2 bolts on the side of the trans that looks liks it hold that thing that the cv bolts up to?
Brandon
PostPosted: Thu Aug 13, 2009 11:27 pm
bout what does it cost to rebuild a trans
Brandon
PostPosted: Thu Aug 13, 2009 11:39 pm
Are you saying you have a side shift 3 rib? You didn’t answer my other questions
PostPosted: Fri Aug 14, 2009 12:05 am
yeah its a side shift i dont know if it has acorn nut or not
Brandon
PostPosted: Fri Aug 14, 2009 4:27 pm
i drained it didnt see any metal
Brandon
PostPosted: Sat Aug 15, 2009 12:53 am
well i found out what it was i was soo glad it wasent the trans it was the brake rotor where it has the splines that goes on your stub axle the grooves were wore out
Brandon
