It is currently Sun May 03, 2026 6:28 am
PostPosted: Sun Dec 14, 2008 10:55 pm
Alright I was wondering what makes up an 1835 , I kno thats what Im running and thats bout it for sure lol, But someone told me I have the 044 heads? So is it still a 1835? Im new to the vw motor, always been a 4wheeler guy any help would be great . thanks
"IT IS WHAT IT IS"
PostPosted: Sun Dec 14, 2008 11:00 pm
69 crank and 92 pistons i think
PostPosted: Sun Dec 14, 2008 11:01 pm
heads will not change the cc s
An 1835 is a stock 69mm stroke and 92mm bore pistons. Some will tell you that the 92s will not last but I know people that ran them for years with no problems so run em until they are wore out.
044 heads is the casting number of them. This number can be found by popping off the valve cover and looking behind the rocker shaft. Different casting numbers have different flow rates and chambers which affect the way the engine performs. 044s are a good performance head for most situations.
Aut Viam Invenium Aut Faciam!
PostPosted: Sun Dec 14, 2008 11:04 pm
alright thanks a lot , Ive been running this motor for 2yrs, god knows how long it was ran before that and it still screams has not one problem, Reason I was asking is because my buddy i ride with has an 1835 and mine seemed to have more nut behind it.
"IT IS WHAT IT IS"
PostPosted: Sun Dec 14, 2008 11:13 pm
a 1835 is a good engine hook it to a 3rib and a set of 31 inch tires good combo
PostPosted: Sun Dec 14, 2008 11:22 pm
exactly what im running, Although my first gear seems short? I guess is how to say it a lil to slow
"IT IS WHAT IT IS"
PostPosted: Mon Dec 15, 2008 4:46 am
Go get you a six rib with that tire engine combo. Use your three rib bell housing and keep your starter. Some simple mods to trans mounts and you got a great first gear climber. Or go to 35's and be easy on that tranny,,or at least that is my experiences.
PostPosted: Mon Dec 15, 2008 11:39 am
ic..Im looking for a bullet proof setup thats not so hard on the wallet, I already havta get some 930 cvs or go bus to bus I blow atleast one car a weekend in wellsville Im not gentle with it
"IT IS WHAT IT IS"
PostPosted: Mon Dec 15, 2008 12:02 pm
Cam and heads make a big difference. My little motor runs with some quite a bit bigger because of little things. Good heads make power. 8)
PostPosted: Mon Dec 15, 2008 12:43 pm
yea i noticed, when we would be climbin he always seems to be a little under powered, where mine is just pullin strong the whole way up
"IT IS WHAT IT IS"
