It is currently Sun May 03, 2026 1:29 am
 Post subject: reamer
PostPosted: Wed Nov 26, 2008 8:52 pm
where can a man get an adj reamer for king pin bushings ? or if they arent available who rebuilds spindles ?
 Post subject: Re: reamer
PostPosted: Thu Nov 27, 2008 1:22 am
For the best fit,I have an automotive machine shop "hone" them on a wrist pin hone
PostPosted: Thu Nov 27, 2008 8:42 pm
Funny, i have been looking for the same thing. Through my research, I have learned that you need a reamer that can adjust to .710. For the adjustable reamer you will want to buy a 21/32 to 23/32. Most retail shops have this labeled as a size D. (I have no idea what the D is for)
If you google search "adjustable blade reamer", you will get several hits. The imported ones are $40 - $50 and a good one will run you $120 or so. The challenge is finding one that also comes with a Pilot.
I have decided to let a local machine shop ream mine for $40.
Good Luck
Dan
PostPosted: Thu Nov 27, 2008 8:48 pm
Here is a cool video of a guy rebuilding his king pins...
http://www.kustomcoachwerks.com/movies/spindles.mov
PostPosted: Thu Nov 27, 2008 11:45 pm
The "D" stands for DA 1 you need. :lol: :lol: :lol:
I would go with the machine shop if they screw up they'll fix it.
WHEN IN DOUBT DRINK ANOTHER BEER!!!!!!!!!!
PostPosted: Sun Nov 30, 2008 6:46 pm
I've got mine from McMaster Carr. I used the long reach reamer. Here's the link: http://www.mcmaster.com/
PostPosted: Fri Jan 02, 2009 7:04 pm
18mm? When i did mine i used an 18mm regular ol reamer i did howerver clamp the carriers down to my bridgeports table. Seemed to work?
