It is currently Sun May 03, 2026 9:27 pm
 Post subject: Wheel base
PostPosted: Mon Jun 30, 2008 5:33 pm
What does everyone like as far as wheel base goes? I am new to buggies and figure longer is better to an extent but I don't want to assume anything. I am looking for a frame to start off in and have found a couple shorter rails around but figured I may want to stick to a longer one. I am trying to get an idea on frame and motor and trans combos for something to start off in. There is a buggy in the for sale section that a few have said was a good deal and I am looking at it pretty strong but was curoius about motor size and trans in stock form or better to regear. I guess it all matter on tire size etc. but I was trying to get an idea of a set up. Maybe a 1915, 3-6 rib and 35's? Just throwing something out there to get some ideas.
Thanks.
 Post subject: Re: Wheel base
PostPosted: Mon Jun 30, 2008 7:10 pm
i run a 96" wheelbase ( warrior frame with beefed up stock trailing arms) My motor is a 1915 and i run a stock 5 rib, i love the gearing in it. Right now i am running 31 x 12.5 x 15 v bars. -- It seems to work very well together.
PostPosted: Mon Jun 30, 2008 10:23 pm
I have a 1835, 3 rib, and 31 15.5 15 ditch diggers. My buggy is 116" 4seater. I was running a 1915 and a 6 rib. I do beleive that i would like a taller tire with the 3 rib.
Wildcat
PostPosted: Tue Jul 01, 2008 12:03 am
i have a 2180cc with a 3 rib and 35 15 50 boggers and wheel base is 106 with 2x3 arms 2 seater
PostPosted: Tue Jul 01, 2008 9:16 am
2332cc with 6rib. 101 wheelbase (with 2x3 arms). 31 firestones.
If you are going to run the 1915 with 35's I would stick to the 3rib. When you get into regearing the transaxles it can get a bit pricey. The 3rib won't take as much motor to turn those 35's.
"Lets go get stupid"
PostPosted: Tue Jul 01, 2008 10:14 am
Thanks for the info. I was just throwing the 35's out there for an example. The firestones and all must do very well, I see a lot of buggies on here that run them. I don't want to start getting a bunch of stuff and none of it work together. I don't want to hit a hill and it bog from not enough motor for the tires or the other way around. LOL
PostPosted: Tue Jul 01, 2008 10:34 am
1915 with firestones and a 3rib would do very well. get ya some 2x3 arms and setup the suspension correctly and your ready to rock.
PostPosted: Mon Jul 07, 2008 7:47 pm
102" w.b. with 31" bar trads. was runnin a 1641 and have had a 1915 in for awhile. will pull the wheels up if i try but stay down if i dnt
PostPosted: Tue Jul 08, 2008 2:05 am
Not "Firestones and all", only firestones as far as v treads go, IMO.
Cut boggers or cut 23 degree firestones both work very well. PLEASE dont waste your money on any v-tread besides a cut 23 degree Firestone 4 or 8 ply if you plan on riding rough stuff at all. They are both pricey, but , like Roy says , buy the best and cry only once.
If you plan going with a taller tire than 31", and not a big motor to turn them, Kyle is right about the three rib gearing working well. But they are weaker and the big tires ( bigger than 31") are even harder on them. Its not a matter of if it will break, but when.
The wheel base you are wanting will depend on where and how you plan to ride. Shorter is easier to maneuver thru tight stuff, but more likely to lift too much when climbing, unless you run some kinda custom long arm. (Longer than the standard 2x3 or 3x3). Get the rear arms too long, and you loose traction, especially the lighter the buggy is. Mine is about 100" w/ 2x3's and 1x2's up front.
PostPosted: Wed Jul 09, 2008 11:28 am
Yeah, I was leaning toward the boggers when I first started looking at buggies and stuff but I knew they where heavy and I didn't want to put too much tire and not enough motor on them. I didn't relize there where that many differnet v-tread tires out there glad you mentioned it. I have been looking at some in the 100" wheel base range or close to it. I hope to have something before long and then will have a ton more questions I am sure.
PostPosted: Mon Jul 14, 2008 8:33 pm
My buggy is a 98" frame but with the extended arms it comes out to about 100". Nice all around length for general use.
PostPosted: Mon Jul 14, 2008 11:28 pm
121 in with 44 TSL
thats my choice
PostPosted: Mon Jul 21, 2008 4:33 pm
When mine is finish it will be 130" or approximatley the legth of a river barge
PostPosted: Tue Jul 22, 2008 7:38 am
Me too!!! Got up to 101 here yesterday!!
PostPosted: Wed Aug 13, 2008 2:29 pm
Mine started life as a 92" Berrien with 5" added in front of the torsion moving just the engine/trans and wheels back. I'm running beefed stock trailing arms but going to 2X3 arms this winter. SOooo... right now I am 97" but next spring will be at 100" without being any longer overall than the day it was built.
Aut Viam Invenium Aut Faciam!
PostPosted: Thu Aug 14, 2008 12:55 am
I am running 105 inches (smallest 4 seater I could find) with an 1835 and a 3 rib trans.
