It is currently Sun May 03, 2026 8:55 pm
Post new topic Reply to topic  [ 88 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Thu Feb 28, 2008 8:22 pm
Got seats and belts installed on mon. and tues. Also got cables installed and adjusted.
Started on body yesterday.[wed]
Mounted winch, roller fairlead, and two lights before leaving on wed.
Mark
High speed
Low drag
Teflon coated
And ready for action!
PostPosted: Thu Feb 28, 2008 8:29 pm
Looks good :D Dave T
PostPosted: Thu Feb 28, 2008 9:44 pm
very nice looking buggy you have. That front end work is nice. Time to test it out and ride.
The Wild Kids
PostPosted: Thu Feb 28, 2008 9:50 pm
is that aluminum your using for the body.
PostPosted: Thu Feb 28, 2008 9:52 pm
I want to put a body on mine just need to figure it out some how.
The Wild Kids
PostPosted: Thu Feb 28, 2008 10:03 pm
Not alum. ---its race car plastic -- .125 thick-- takes a hell of a lick! Use a brake to make bends that hold there shape. 4x8 sheet $40.00
Mark
High speed
Low drag
Teflon coated
PostPosted: Thu Feb 28, 2008 10:32 pm
lookin good mark when i go to bristol this fall i will come back an see your shop
PostPosted: Thu Feb 28, 2008 10:35 pm
Do you have a brake to ned it up? I want to do that to mine and thats cheaper than the sheeting I was looking at. How do you have it fastened onto the frame? Looks great and clean looking.
The Wild Kids
PostPosted: Thu Feb 28, 2008 10:43 pm
Looking good!!
PostPosted: Thu Feb 28, 2008 10:55 pm
Not sure of the Question, but in the pics I have used self drilling screws to hold into place till I get the color matching pop rivets installed. I will post some pics tomarrow of them installed!
To fold the plastic with a sheet metal brake makes a cleaner -more defined bend. I have tried bend it with boards and angle iron clamped on top of the plastic and force a bend---- but it doesn't look like the bends from a brake. We have placed the sheets on the sides of buggies with self drill screws --no folds--- still looked good!
Mark
High speed
Low drag
Teflon coated
PostPosted: Thu Feb 28, 2008 11:17 pm
Sorry my fingers got criscrossed while I was typing. I was asking if you had a brake to bend it. I have tried the clamps and angle iron before with OK results but I would like a cleaner look.
The Wild Kids
PostPosted: Thu Feb 28, 2008 11:31 pm
I bought a cheap 36" brake from Harbor Freight for $145.00 a couple year ago. It does a good job on any thing that is under 36"! It is hard to do a box with it since it has no grooves in the blade to let edges slide between when folding.{ hope you understood that rambling} The more I use it the more I wish I had a better brake?
Mark
High speed
Low drag
Teflon coated
PostPosted: Fri Feb 29, 2008 3:07 am
Understand, maybe I can get you to help me with my body on the rail sometime later on this summer. I have always wanted a body on the thing.
The Wild Kids
PostPosted: Fri Feb 29, 2008 8:14 pm
Anytime is fine with me!
I got a small amount more done on buggy while at work today. Got a pic of color matching pop rivets [there close!]. I finished the hood frame and made a couple of bends on the cover sheet. Am going back tomarrow to finish hood. I have been doing the work on buggy when we have nothing to do at work--- we are still a little slow. I am at 100hrs. on buggy buid. I hope to get on the wiring next week! I still have not decided on what I am going to do for covering the roof. the last buggy had a fiberglass top that I built ----A LOT OF WORK !
Mark
High speed
Low drag
Teflon coated
PostPosted: Fri Feb 29, 2008 10:57 pm
Looks good, if your going to serious woods ride I wouldn't think of nothing but a metal top. Street use I still would go metal but might consider something else.
Just my 2 cents worth.
The Wild Kids
PostPosted: Sat Mar 01, 2008 8:35 pm
Went to my work this morning to work on buggy. Since the service department is closed on saturdays, there was noone there to bother me and I got a few small things done. I finished the hood and got most of the rivets put on to the side panels. I made two of the four winch power cables and installed them from the winch to the control box. I mounted the control box on kick panel in front of pedal assembly.May be able to start on wiring soon.
Mark
High speed
Low drag
Teflon coated
PostPosted: Wed Mar 12, 2008 9:56 pm
Hubs and front wheels painted today. Got switch box mounted and wiring ran this week-all wires ran and hooked up. Will hook overhead lights after roof panel is installed-- should be first of the week. Still waiting on hydrolic hoses that are being made!
Mark
High speed
Low drag
Teflon coated
PostPosted: Wed Mar 12, 2008 10:07 pm
lookin good mark its almost time to get it dirty
PostPosted: Wed Mar 12, 2008 10:09 pm
Hope to get to move it next week!!!
Mark
High speed
Low drag
Teflon coated
PostPosted: Thu Mar 13, 2008 3:49 am
Sharp looking job you've done. Hope to see it up close some time soon. Wit me getting a job I will have some money to put into my buggy.
The Wild Kids
PostPosted: Thu Mar 13, 2008 5:14 pm
Thanks for all the good replies. Good luck with new job.
Mark
High speed
Low drag
Teflon coated
PostPosted: Thu Apr 03, 2008 10:51 pm
Wewere slow at shop today =guy in back said there wasn't enough room for him to get in -he was wrong! The guy up front is making the engine sounds. :lol: Today I got all but one fitting to finish power steer/auto stick hoses. Hope to prime system w/ drill tomarrow!
Mark
High speed
Low drag
Teflon coated
PostPosted: Thu Apr 03, 2008 10:59 pm
looks great!!!
Mike
Got Honda?
PostPosted: Thu Apr 03, 2008 11:04 pm
looking good :D :)
PostPosted: Thu Apr 03, 2008 11:19 pm
great lookin buggy!!!!!!!!
