It is currently Sun May 03, 2026 4:29 pm
Post new topic Reply to topic  [ 88 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Sun Dec 23, 2007 4:49 pm
Thanks, both of y'all.
buggy66 ,
The buggy I'd like to do something like this to already has a 6 rib in it, so its already set up for bus. Does this conversion push motor further to rear of buggy? Its just been powdercoated, and aint a whole lot of room between stinger and rear of cage already. Its a 10:1 5.5" rod 2276 w' dual dell 40's, 31" diggers.
So actually the only thing autostick about it is the clutch/converter assembly?
And you can sit on a hill w/ your foot on the brake, tranny in gear, and just hit the gas and release brake and it goes? My wife's only gripe w/ manual is shes worried about taking off in the middle of a hill, while trying to hold brakes. Doesnt wanna roll back, kill it, blah blah blah.
John,
Hope you guys have a Merry Christmas, too. Hope I can get wifes buggy up and going early spring, so theres a seat for my little one. He wont go riding unless he thinks Tylers gonna be there!!
PostPosted: Sun Dec 23, 2007 5:03 pm
I want to say it moves the eng back almost 3 inch. If you have tri mill exhaust coming up in rear of eng like most of do / you could make change there? The guys I ride with run a one piece adapter and cost somewhere around 400.00 I used to know of a used one for half that. I have some of the parts for auto sticks but not everything. 423/612/9619 Mark
PostPosted: Sun Dec 23, 2007 5:42 pm
Thanks again. PM sent.
PostPosted: Sat Jan 12, 2008 7:04 pm
Here are some new pics on my four seat build which is now at 84hrs.
Pic of front shock hoops.
Seat mount for childs seat.
Tree bars
Front seat harness bar that has four inch offset to match driver seat offset.
Winch [5500#line pull]mounted behind lights on push bar.
The small things are taking soooooooo llllllooooonnnngggg!!!!!! Put it together and take it apart! Cant wait to ride. Hope to get epoxy primer on frame by the end of this week---at latest mid week after.
PostPosted: Sat Jan 12, 2008 11:54 pm
looks very nice
PostPosted: Sun Jan 13, 2008 1:30 am
awesome, almost there!!
Mike
Got Honda?
PostPosted: Tue Jan 22, 2008 7:41 pm
Build at a stop for about a month! My appendix blew out on me on thursday evening. I have a four inch cut across my guts! ---Can't work or play with buggy for at least a month! Mark
Mark
High speed
Low drag
Teflon coated
And ready for action!
PostPosted: Tue Jan 22, 2008 7:59 pm
sorry to hear that---take it easy and heal up--buggy will wait on you
PostPosted: Tue Jan 22, 2008 8:03 pm
Heal up it will be there when you are better. No hurry on it.
The Wild Kids
PostPosted: Mon Feb 11, 2008 10:33 pm
Went back to work today! Got nothing done, but cleaning up around work area. Did get steering arms {made with 3/4" heims and 1" tubing} painted today> Am hoping to get pitman arm made tomarrow! Also hope to get hi-lift jack mounted. I am going to mount a solid bar on the side of frame --to help move the big rocks into possition when climbing. It might be over kill- but noone ever has the things you need on the trail! I will let you know how it goes as I make progress. Mark
Mark
High speed
Low drag
Teflon coated
PostPosted: Thu Feb 14, 2008 10:37 pm
Lastest pics of steering components.
I am now at 92 hrs and have started some of the painting.
You can see that the frame will be black. In the background you can see a large plastic panel that is blue -that will be the side body peices.
Mark
High speed
Low drag
Teflon coated
PostPosted: Sat Feb 16, 2008 12:09 am
You've came a lon way since we came up there and got your old buggy lookn good man!! :eek: :eek:
Lets Ride!!!
PostPosted: Sat Feb 16, 2008 7:26 am
Is there any other color? That's the best! :wink:
PostPosted: Sat Feb 16, 2008 8:27 pm
Lookin very cool!
Jim
D. Marks wrote:
The only time I hug trees is while I'm carring them out of the way.
PostPosted: Sat Feb 16, 2008 10:55 pm
Took a couple pics to show some of the tools I will be taking on the trails--- have borrowed from others that we have rode with!
This pic is of the skid plate laying on front tire and waiting to do final cut at the last tack weld where cross bar is. Looks heavy -huh! I like to over think and over build sometimes!
Mark
High speed
Low drag
Teflon coated
 Post subject: Skid plate
PostPosted: Sun Feb 17, 2008 9:19 am
Very nice :D We could have used a plate like that a few years ago, would have saved an engine when the push rod tubes got tore out :evil: . Dave T
PostPosted: Sun Feb 17, 2008 9:22 am
Did you make that pitman arm?
PostPosted: Sun Feb 17, 2008 11:40 am
I took a stock S10 pitman arm -cut the tie rod end off - cut a piece of 3/4" steel plate the shape needed to fit heims and fitted it to the pitman arm - them welded. It seams like it will work fine.---should be strong enough!
Mark
High speed
Low drag
Teflon coated
PostPosted: Mon Feb 18, 2008 2:07 pm
Lookin good! Love the way the "pick-up" style rear section looks.
Gitterdun, so you can start on that auto-stick conversion for my wife!
Just kiddin' , no rush, I cant even get the rest of her buggy done :roll: .
PostPosted: Mon Feb 18, 2008 2:12 pm
The buggy looks good, looks like you are gonna be the rescue guy :lol: , keep up with the good work.
PostPosted: Mon Feb 18, 2008 6:47 pm
Thanks guys. Cant wait to ride -hope to see all soon!Rescue I will if I can! :lol:
Have already started on adapter for you Larry. Will post you later.
Mark
High speed
Low drag
Teflon coated
PostPosted: Sun Feb 24, 2008 3:41 pm
New pics -these are of the brake lines and power steering lines. Also you can see parts of the mat I cut and placed between rails to kept floor pan from sounding like a bell [used 14guage steel sheet metal for floor pan].
This is just a shot of gas tank, oil cooler and oil tank.
Mark
High speed
Low drag
Teflon coated
PostPosted: Sun Feb 24, 2008 6:08 pm
How did you couple the hard lines for the power steering to the hoses? I assume a compression fitting.
PostPosted: Sun Feb 24, 2008 9:29 pm
I did use compression fittings. I am going to try them first. I know the pressure will not be to much but dont know about the heat --should work ok. If it happens to leak I will silver soilder them -then no leak!!! The hard part was bending to fit.
Mark
High speed
Low drag
Teflon coated
PostPosted: Sun Feb 24, 2008 10:47 pm
[quote='Roy']You can see that the frame will be black.
Is there any other color? That's the best! :wink:[/quote]
in your avatar pic your buggy looks purple.
- Sigmund Freud
- Antonio Meloni
