It is currently Sat May 02, 2026 6:07 pm
Post new topic Reply to topic  [ 58 posts ]  Go to page Previous  1, 2, 3
PostPosted: Sun Oct 21, 2012 2:12 pm
How big you going? Go really big! It's only money!lol.a lot of things to think about and every combo imaginable to rack your brain.but in the end build it to suit your riding style and what you like to do the best.if you don't put lots of miles at a time and really like to climb the toughest hills out there then go as big as you can afford.once you build up to a 2276 your basically the same money to go to a 2387 if you have to buy all new as in crank rods cam and machine work plus 94's.I know it's pretty expensive to build one up without nothing,I just picked up my new motor and have over 3500.00 in it and that's just a long block,so you can really put a lot in one if you want to.I know you w/c guys will love bashing me on that but that's what I wanted.a good 1915 with really good heads and cam will ride forever and take you anywhere you need to go if you can drive but a 2332 will do the same and give you a little more play factor as far as climbing.no matter what you build on the bottom end spend really good money on your heads and build it up beneath them IMO.heads are something that will make or break you on having a good motor far more than a cam crank rod size.Chad :mrgreen:
PostPosted: Sun Oct 21, 2012 2:54 pm
If you know how to drive a built 1915 with great heads and a cam will climb anything. Keep the weight down on your rotating mass and hang on. WC guy's think spending crazy money is fine if thats what you want. I have a wife and kid that I have to provide for. Not to mention I have the biggest rail in three States. Finally found a hill I couldn't climb, need tires with big lugs.
PostPosted: Mon Oct 22, 2012 6:21 pm
Guys, This motor is going on a rail buggy.... It won't see alot of off road use ???? What motor would you build ???? I like fast but I like dependable ....
if it aint broke fix it till it is....
PostPosted: Mon Oct 22, 2012 6:49 pm
Build what you and you wallet find best, it is as much personal preference. If you can build a bigger (displacement) engine for the same money then you are better served by doing so. Again I believe from his posts that Aaron Creech is a great resource as far as what works best for your budget. So I would speak with a pro builder to get the most out of our ever shrinking dollar.
PostPosted: Mon Oct 22, 2012 7:37 pm
i agree with these guys, its what YOU want.. gasman did hit the nail on the head when he told you that heads and carbs is where its at..anybody that has spent time in the woods has seen that lil 1835 that will SCREAM and put all the bigdogs on the trailer :twisted: ..
LEGALIZE BLUEGRASS!!!
Save a tree... eat a Beaver
PostPosted: Fri Oct 26, 2012 8:35 pm
The 1915 I built for my buddy Dave runs just as good as the 2276 I had in my black buggy.
PostPosted: Mon Oct 29, 2012 3:00 am
all about the heads
PostPosted: Wed Oct 31, 2012 7:23 pm
2387 ported heads dual carbs 10 to 1 comp. runing 50/50 pump gas fk42 or 43 cam or 110 or 120 .Cam for geering tires and LBs of buggy.
