It is currently Sat May 02, 2026 11:20 pm
PostPosted: Thu Oct 18, 2012 9:43 pm
Thats what its coming down to holeman ive checked everything else if it dont run right once i put it back together i will be trying points again i never had big issues with the points in previous motors only reason i put petronix in was because thats what was in it when i bought it and was trying to keep it the same
PostPosted: Thu Oct 18, 2012 10:44 pm
Where are we measuring the float level at? the side nearest to the needle jet? Or out at the end of the float? I measure mine out at the end, and mine is very picky about being about 13-14 anything less an it floods the bowls an runs like poo , just my experience
"IT IS WHAT IT IS"
PostPosted: Thu Oct 18, 2012 11:09 pm
i had two of the electronic systems go bad on mine.now i just keep a spare set of points with me in case my points get wet while ridding.
PostPosted: Fri Oct 19, 2012 8:49 am
Jayrod i measured them out at the end
PostPosted: Fri Oct 19, 2012 4:57 pm
Got everything put back together turned the key on heard a pop which sounded like it came from the dist so im assuming my petronix shit the bed turned it over to see if i had spark and couldnt quite tell so grabbes the plug and waiting to get zapped.nothing there so gonna go get points and condenser i dont wanna keep forking 70+ dollars on this ignition i will be getting ahold of the manufacturer and sending these back all my coils i had have internal resistors and was reading good and even threw the flamethrower coil on beings it is the only one they say the warranty would be good with for that ignition
PostPosted: Fri Oct 19, 2012 5:32 pm
hey man check to see if you have a ground on your ignition wire to your coil
PostPosted: Fri Oct 19, 2012 5:34 pm
but i gave up on electronic ignition long ago.they work great when they work but go bad with no notice.
PostPosted: Fri Oct 19, 2012 5:56 pm
It has red and black wire they were all hooked up the same as before
PostPosted: Sat Oct 20, 2012 4:11 am
ive got a petronix in 2 of my motors one since 03 the other since 06 and buddy of mine has one he has been running for i know 12 year all with bosch blue coils and never had a issue, if you having issues its something besides the petronix itself, if its blowing the petronix by turning on the key it sounds like its hooked up wrong or a bare wire shorting somewhere
PostPosted: Sat Oct 20, 2012 8:18 am
X2 on not hooked up right or grounding out. I trouble shoot for a living. When I switched mine over from points Lisa was telling me how to do it. Of course I let her no how skilled I was and went on my way. Next day I was buying a generic one saying this petronix was bad out of the box she just laughed and said " yea yea that's what they all say ". My generic one still strong 4 yr later. You have to no wich ones the ground. Mine were mixed up. I had to use meter and follow everything back. Points didn't care petronix did.. I did tranny swap 3 to 5.,didn't recheck throttle stop. Every ride it got worse. I cleaned them messed with isles over and over. The nut on shaft they holds butterflys was loose. Couldn't get them to syncro. Finnaly after noticing nut tightening it synched them running like new. My crunch is back no popping and bull. So needless to say I will never underestimate important of throttle stop. I tried everything before I figured that out. 9 times out of 10 its something simple. User error. Hope ya get it. Nothing worse than are rail not running right. MIGHT news a fresh set of eyes on it. Usually helps
PostPosted: Sat Oct 20, 2012 12:01 pm
i think wrongway is right i think i have a wire thats going to ground but for the life of me i cant find it.like wrongway i trouble shoot for a living also being an electrican.planing on a total rewire this winter.
PostPosted: Sat Oct 20, 2012 2:32 pm
I put new points and condenser in its running allot better still breaking up in 2nd a little i still have my flamethrower on with internal resistor i have a accell super stocks reading 1.5 ohms.is the flame thrower having too much resistance for stock points
PostPosted: Sat Oct 20, 2012 8:10 pm
Oh by the way I didn't actually figure it out. I was tripping on the way they were acting and I called creech, he me if I was sure my throttle stop was right, i thaught it was completly forgot about changing out trannys. Little shit like that just kicks my ass. Too many smoke breaks lol. Thanks Aaron for taking a call from a brother when he has his head up his ass. Haha. Cant wait to ride. Boo fest. DTOR next weekend.
