It is currently Sat May 02, 2026 8:42 pm
Post new topic Reply to topic  [ 31 posts ]  Go to page 1, 2  Next
 Post subject: Help
PostPosted: Sat Dec 08, 2007 12:19 pm
Hill Climber
My motor won't fire. I changed the dist. coil, and ignition. No change.I wired it straight from bat. to coil. Nothing. It does back fire a little. sounds like it's out of time but it should be ok. I have it set at 10 before TDC. Any ideas.
Thanks
Dean
PostPosted: Sat Dec 08, 2007 12:21 pm
Hill Climber
I have fought this last night and all morning. I am in no mood to be told to put a wc in it.
PostPosted: Sat Dec 08, 2007 12:24 pm
water..........condensation, in your fuel?
Mike
Got Honda?
have you ck the plugs may be wet for some reason
PostPosted: Sat Dec 08, 2007 12:57 pm
TRY PUTTING GAS IN IT!!!!!!
PostPosted: Sat Dec 08, 2007 1:22 pm
Hill Climber
Gas is fine. Getting plenty of it thank you DVS1. Electronic ignition. tried two of'em.
PostPosted: Sat Dec 08, 2007 1:31 pm
check your coil. it may seem fine but this happened to me. i had to buy a new blaster 2 coil
PostPosted: Sat Dec 08, 2007 2:02 pm
check the battery ground,,,,,or something 8)
PostPosted: Sat Dec 08, 2007 3:29 pm
Have you changed anything since the last time you have had it out? (replaced changed anything) Plug wires where they're supposed to be?
PostPosted: Sat Dec 08, 2007 4:26 pm
Hill Climber
Broken cam shaft
PostPosted: Sat Dec 08, 2007 4:32 pm
Sucks.... :-x
PostPosted: Sat Dec 08, 2007 4:43 pm
You got just enough time to get'er fixed for the Creek ride. 8)
PostPosted: Sat Dec 08, 2007 5:52 pm
I would have never guest that.
PostPosted: Sat Dec 08, 2007 6:54 pm
how did your cam break? was you running then it broke, or just trying to start it up after it was sitting since your last ride?
PostPosted: Sat Dec 08, 2007 7:19 pm
Hill Climber
[quote='Steve']I would have never guest that.[/quote]
Me either. Never heard of such a thing. Oh and the wc coments can start I'm in a much better mood now.
PostPosted: Sat Dec 08, 2007 7:57 pm
If I broke one I would have one left. :P
PostPosted: Sat Dec 08, 2007 8:01 pm
[img][img]http://i223.photobucket.com/albums/dd87/jem203/CAM.jpg[/img]
Would you want me to clearecne one for you?? No its not mine!![/img]
PostPosted: Sat Dec 08, 2007 10:46 pm
you gona have her back together by the weekend
PostPosted: Sat Dec 08, 2007 10:59 pm
Hill Climber
Well. First off I have NEVER claimed to be and engine builder. The cam may not be the problem. I am stumped. I will be making the 4 hr drive south in the morning to Shadetree Performance. Were I am sure he will take one look at my unassembled motor and tell me what I did wrong. But when I leave it will run.
PostPosted: Sun Dec 09, 2007 1:02 pm
dont feel too bad dean, just think about my motor. Two half ass rides and the cranks toast. Gotta love VW's, or well in my case operator error.
PostPosted: Sun Dec 09, 2007 1:40 pm
Never kick a man when he's down. Did they leave a radius when the clearenced the cam. If not that's what will happen. That sucks
PostPosted: Mon Dec 10, 2007 9:29 am
what do you mean by radius? are you refering to how the cam was clearenced?
PostPosted: Mon Dec 10, 2007 9:41 am
When machine cutting you need to leave a radius at the root of the cut otherwise it will crack there from the stress.
PostPosted: Mon Dec 10, 2007 10:43 am
Sounds like the dist. lifted up and is not rotating.I have seen this e few times with aftermarket brackets.
PostPosted: Mon Dec 10, 2007 12:14 pm
Hill Climber
Motor is running. Thanks guys!
