It is currently Sun May 03, 2026 9:20 am
 Post subject: Wheel base
PostPosted: Sun Dec 02, 2007 8:30 pm
Hill Climber
I am kicking around a couple ideas to help my buggy climb. They both include a longer wheel base. Right now my wb is 93". Pretty short I think. Can you tell me what the wb is on some of your buggies? And what you like or dislike about it. I am trying to figure out how long is to long.
Thanks
Dean
PostPosted: Sun Dec 02, 2007 9:04 pm
Personally I would not go over 100" WB if your going to trail ride. Even at 100" tight trails can be tricky to manuver thru. Power steering would be a great help on longer wheel bases so I would consider that if you go longer. I know thats what Im doing on my new Buggy and its only 98".
PostPosted: Sun Dec 02, 2007 9:20 pm
put a SUBARU in it.
PostPosted: Sun Dec 02, 2007 9:22 pm
yea a cd suby :wink:,,,,,oops,,,,,stole a thread,,,,, uh my wb is 102
PostPosted: Sun Dec 02, 2007 9:31 pm
OH YA! mines 100'' stalker. the old car was 103, sorry Dean
PostPosted: Sun Dec 02, 2007 10:10 pm
103"......... modified "beeline, pro 95" frame
Mike
Got Honda?
PostPosted: Sun Dec 02, 2007 10:42 pm
dont know what my frame is but i legenthened it 15" went from 87" to 102" and most of the time all 4's are planted on climbs
PostPosted: Sun Dec 02, 2007 10:56 pm
most of the bama buggys are 105 thats with 3x3s,my 4 seater is 112, but as long as I pay attention on trails I have know problems,I do like the point of sitting closer to the front ,you have a better view
PostPosted: Sun Dec 02, 2007 11:12 pm
120 IN CUSTOM CHAIN DRIVE
ROCKROCKET!
IF YOU AN'T LIVING ON THE EDGE YOUR TAKING UP TOO MUCH SPACE!!!!!!!!!
PostPosted: Mon Dec 03, 2007 1:36 am
106 here cutting brakes are a must on tight trails with a little bit of speed and no worries.
The Wild Kids
PostPosted: Mon Dec 03, 2007 5:40 am
Mine is 100"
PostPosted: Mon Dec 03, 2007 12:37 pm
Mine is about 101"
PostPosted: Mon Dec 03, 2007 9:34 pm
98" now, needs to be 102"
PostPosted: Mon Dec 03, 2007 9:53 pm
mine is 102"
drive it like you know how too fix it
PostPosted: Mon Dec 03, 2007 10:06 pm
105" with 3x3 rear and 21/2" extended up front
- Sigmund Freud
- Antonio Meloni
PostPosted: Tue Dec 04, 2007 10:11 am
Mine is 100 inches dean, same frame as hillaholic.
PostPosted: Wed Dec 05, 2007 8:35 am
Dean mine is 100-102. i havn't checked it since i put ext. arms on the front. But length is not as important as most think. Its all about suspention,balance,and low center of gravity. I know alot of short buggies that climb good.Most guys at D and K are under 100.Look at Smitys.
PostPosted: Wed Dec 05, 2007 10:20 am
Where do you measure the wheel base from? From center of wheel to center of wheel, or total length of frame?
PostPosted: Wed Dec 05, 2007 10:24 am
Wheel centers
PostPosted: Wed Dec 05, 2007 11:43 am
AROND HEAR 99-101 IS IDEAI FOR TRAIL RIDEING AND HILL CLIMBING MINE WAS 97" AND COULD NOT KEEP IT OFF THE ROOF I MOVED IT TO 100 1/2 IT HELPED ALOT..
PostPosted: Wed Dec 05, 2007 1:53 pm
101-102, I think.
PostPosted: Wed Dec 05, 2007 2:23 pm
single seater 100" , two seater 98"
PostPosted: Wed Dec 05, 2007 9:58 pm
I'm at 90" . I've had the same thoughts as you, My front end is usually aimed at the sky on some of the steeper hills & I have an 8000lb winch infront. I'm not sure what to do.
Bruce
PostPosted: Mon Dec 10, 2007 12:22 pm
Mine is 101 1/2" long.
PostPosted: Tue Dec 11, 2007 10:32 am
damn, Gamntrail, thats a heavy winch!!! you must have put heavy springs in your beam!! ha,ha,ha.
