It is currently Sun May 03, 2026 12:55 am
 Post subject: EBAY TRANS FIND MUST SEE
PostPosted: Sat Nov 24, 2007 11:39 pm
HAS ANYONE SEEN THIS BEFORE LOOKS LIKE A GOOD IDEA
http://cgi.ebay.com/ebaymotors/VW-TYPE-2-091-TRANSMISSION-HYDRAULIC-CLUTCH-SLAVE-SAVER_W0QQcmdZViewItemQQcategoryZ6755QQihZ007QQitemZ170170094443QQrdZ1QQsspagenameZWDVW
PostPosted: Sun Nov 25, 2007 12:01 am
Looks like a good idea to me.
PostPosted: Mon Nov 26, 2007 1:17 am
yeah i have one like that on my buggy haven't had a problem out of it yet(knock on wood)can't really tell ya if it makes a difference or not maybe one of the oter guys can tell ya.
when in doubt gas it
PostPosted: Tue Nov 27, 2007 5:00 pm
I got this on a vanagon side shifter, :) had to drill an tap 1 hole :D
PostPosted: Tue Nov 27, 2007 5:11 pm
Kendal, Hows that side shift linkage working out for you. Im in the process of putting a 1984 side shift in my new buggy using that linkage.
PostPosted: Tue Nov 27, 2007 5:26 pm
[img][img]http://i237.photobucket.com/albums/ff85/kcobb1964/dunebuggy013-1.jpg[/img]http://i237.photobucket.com/albums/ff85/kcobb1964/dunebuggy013-1.jpg[/IMG]
I got 4 gears and reverse with that set up steering heims from speedway worked out real nice :D i was able to leave my original shifter set up alone i used mckenzies 10 degree mount but redid it to my liking 8) I think it will work out just fine
 Post subject: more pics
PostPosted: Tue Nov 27, 2007 5:32 pm
[img][img]http://i237.photobucket.com/albums/ff85/kcobb1964/dunebuggy004.jpg[/img]http://i237.photobucket.com/albums/ff85/kcobb1964/dunebuggy011.jpg[/IMG]
I am also doing swing to irs conversion and cage mods It has been crazy bout like initial build :)
PostPosted: Tue Nov 27, 2007 5:58 pm
Looking really good. For some reason I thought you were using the Davis Racing Linkage like I am. What did you use for the pivot point on the shift rod.
PostPosted: Tue Nov 27, 2007 6:24 pm
At the shiftbox i cut a block out of aluminum an put a 3/4 bushing from my local farm an home store bolted it to the inside of th e shift box in place of the nylon bushing for the stock shift rod the heims are .757 dia steering heims from speedway and slide nicely over the tube {3/4 stearing shaftfrom speedway}.I thought about it and think my design shows promise ie stock shifter location ease of heim install plus I have acces to machine tools! :D 8)
PostPosted: Tue Nov 27, 2007 6:28 pm
PostPosted: Tue Nov 27, 2007 7:26 pm
I am sorry I didnt intend on hijacking this thread forgive me :(
PostPosted: Tue Nov 27, 2007 8:55 pm
Kendel now we know what kinda guy you are. Your a thread thieft!
PostPosted: Tue Nov 27, 2007 9:11 pm
Did that front mount come with shift linkage??
Nice car, Is that an explorer?
PostPosted: Tue Nov 27, 2007 9:25 pm
shift linkage came from my mind with inspiration found on this site :D i decided to do a 1 piece thing because it was easy an my trans is bushing mounted so my shifter stays with the trans. All the best stuff you have to build yourself! 8)
PostPosted: Tue Nov 27, 2007 9:27 pm
Very nice work! Do you mind if I use your design??
PostPosted: Tue Nov 27, 2007 9:32 pm
I used a piece of chain welded to a bolt on each end. This way the arm can "arc" as it moves and will not bind. Simple and effective.
PostPosted: Tue Nov 27, 2007 9:36 pm
the frame is a cobra98 beeline :D
Before :roll:
During :(
After :D
PostPosted: Tue Nov 27, 2007 9:38 pm
Fooled me! I thought it was an exploerer. I like the change, I almost did the same type of mods to a berrien.
PostPosted: Tue Nov 27, 2007 9:42 pm
ok you can drill large ball bearing with carbide in the lathe then use pipe to fit close. just stick bolt in hole and weld. Or you can form ball on piece of round stock in lathe an bore a socket out to fit my retainer bolts catch the rod a bout 1/2 so they cant roll or slide. study the pics If a lathe an mill are cheating I am a cheater :D
PostPosted: Wed Nov 28, 2007 2:17 pm
I just figured out that this set up will "flip" your shift patern side to side :eek: that might be ok :D ,that might not, :( could be a theft deterant to go along with your removable stearing wheel and batery disconect
PostPosted: Wed Nov 28, 2007 7:21 pm
i like the x brace the way you bent two pieces looks better than just the x
drive it like you know how too fix it
PostPosted: Sat Dec 01, 2007 9:55 pm
Whats the rear trans mount look like??
PostPosted: Sat Dec 01, 2007 10:35 pm
