It is currently Mon May 04, 2026 11:17 pm
PostPosted: Fri Nov 26, 2010 6:45 pm
Alright i got the mech. fuel pump, i was leaking fuel, I found the one spot which was the line had a small hole from the clamp, the 2nd spot, Is on the underside of the pump opposite from where the lines connect, there is a small hole in the pump Any reason that hole is there? Ive never really noticed this leak before, is it possible that hole was plugged and needs plugged again?
"IT IS WHAT IT IS"
PostPosted: Fri Nov 26, 2010 6:58 pm
you need a new fuel pump, if its leaking out that hole the diaphram is going/gone bad
PostPosted: Fri Nov 26, 2010 6:59 pm
well that sucks....No quick fix to ride for a day? like pluggin the hole ?
"IT IS WHAT IT IS"
PostPosted: Fri Nov 26, 2010 7:01 pm
i wouldnt plug it, it could start leaking fuel into the engine block, straight to thhe oil (not a good thing)
PostPosted: Fri Nov 26, 2010 7:03 pm
yea good point...so then i be screwed for riding tomorrow
"IT IS WHAT IT IS"
PostPosted: Fri Nov 26, 2010 7:05 pm
autozone or advanced usually has the fuel pump in stock
PostPosted: Fri Nov 26, 2010 7:09 pm
im tryin that right now, cant find one around here that has one in stock.
"IT IS WHAT IT IS"
PostPosted: Fri Nov 26, 2010 10:26 pm
Depending on how bad u want to ride, you can get a inline electric pump from advance. Thats what I run on my buggy. Its made by Mr Gasket, its the one with the red label, its a 2 to 5 pound pump. You can use it for 2morrow and once you get the mech pump replaced youll have a spare.
