It is currently Sat May 02, 2026 9:09 pm
PostPosted: Sun Sep 19, 2010 7:43 am
Heading out in a few hours to pick my newest toy up.
Its an 86 fiero on its way to being a woodsbuggy.
It still needs alot of work from me to make it capable out in the woods. Hopefully this type of buggy will be accepted here and I can find some pointers on where to go with it. Ive been in 4x4 rigs for nearly 10 years ever had any 2wder before.
I obvioulsy know I need to do something for ground clearance and tires, and maybe some cutting brakes aside from there no idea where to begin for offroad capabilities.
www.offroadohio.com
86 Fiero turned buggy
PostPosted: Sun Sep 19, 2010 11:01 am
Got it home
Got around ok for walmart all seasons, now to figure otu what to do about traction aides.
www.offroadohio.com
PostPosted: Sun Sep 19, 2010 12:03 pm
that thing looks cool as hell. mayby a little taller tire and i would think that would be alot of fun.
DAREK
I want to die in my sleep like my grandpa. not screaming like the passengers in his car...
PostPosted: Sun Sep 19, 2010 12:53 pm
I am looking into adding a little bit of suspension lift to it. Already order some wheel adpaters to get me to ford ranger/ jeep bolt pattern so I can run put the 235-75-15 dessert dawg tires I have on ranger wheels on the back. Still need to find something for the front.
www.offroadohio.com
PostPosted: Mon Sep 20, 2010 8:19 am
I like it!! :mrgreen:
PostPosted: Mon Sep 20, 2010 8:35 am
coolest thing I ever saw..you will have to do a few mods along the way but hang in there,,,good luck
I have a Fierro radiator in my buggy too :wink:
PostPosted: Mon Sep 20, 2010 8:47 am
thats cool, who looks at a fiero and says let off road it :shock:
PostPosted: Mon Sep 20, 2010 3:48 pm
Im debating right now on pulling the carrier out of the trans and welding it ( no lockers out there for it), or trying to fab up cutting brakes using the ebrake cables ( it has rear disc with ebrake equipped calipers)
I know the pros and cons of both my question is which one truley helps out the most in a rear engined buggy? I come from the 4x4 world and we lock both ends and call it a day and make 8 point turns if we have to.
www.offroadohio.com
PostPosted: Tue Sep 21, 2010 12:11 am
i would go with the cutting brakes cause when you weld it its gonna try and go straight when you need to turn and if its slick or on much of a hill the front tires wont have enough traction to "make" it turn, plus in the 4x4 you had the benefit of the front wheels pulling and turning
PostPosted: Tue Sep 21, 2010 12:23 am
Welcome to the site!
Absolutely... the cutting brake. I would try to run them hydraulic though. Cable might be harder to pull/hold and have more travel in the handle. Also, IDK about the Fiero, but on some cars the E brake only applies a couple small shoes which rub on the inside of the rear disc hub,like a small drum brake system inside your rear rotors. not much stopping power.
Very cool rig! I heard there were some folks running those with really good success.
PostPosted: Tue Sep 21, 2010 4:17 pm
Cool rig! Welcome to the site :D
Mike
Got Honda?
PostPosted: Tue Sep 21, 2010 9:06 pm
The fiero cable moves the entire caliper piston in so you get the same brake applied as when hitting the pedal, you just have to pull ti hard ot get the same pressure I am sure.
I run my 2wd ranger tough truck welded with steerign brakes up front and it seems to do fine on the track, but thats not out in the woods. Heck it turns so good I rooled it over making a slick corner thursday.
However cable powered cuttign brakes on the fiero will be very easy to do I just need to get another brake lever and main cable to amek it work. I will try that route and see how I like it. If I feel later on I need more pressure and can justify the exspence of hydraulic Ill go that route, plus I need working emergancy brakes to pass the inspection to get the rebuilt title for it so I can tag it.
www.offroadohio.com
PostPosted: Wed Sep 22, 2010 7:55 am
That's too cool! 8) I wana see it in action! Oh, and welcome to WoodsBuggy! There's unlimited info on this site, and never be afraid to ask any question! Try to make it to D&K for the last big hill climb of the series, October 16th. :D
-Dakotah/koko
JeffClay wrote:
-Dakotah/koko
keep on keepin' on!!
PostPosted: Wed Sep 29, 2010 7:12 am
Spacers arent hear yet but here is how it wills it with my bigger street tires on the rear ( I have offroad only tires that are the same size)
www.offroadohio.com
PostPosted: Wed Sep 29, 2010 7:51 pm
got the 2nd brake lever installed for the cutter brakes, need another main cable to get it all functioning correctly, but one side is hooke dup and working.
www.offroadohio.com
PostPosted: Thu Sep 30, 2010 3:04 am
Kool ride Donnie,let me know if you need anything(pm for my cell) Let me know when its ready we'll hit Clints
PostPosted: Thu Sep 30, 2010 7:21 am
Im planning on taking it to clints for the Halloween Ride the 30-31st.
www.offroadohio.com
PostPosted: Fri Oct 01, 2010 2:24 am
Kool c ya there
PostPosted: Fri Oct 01, 2010 8:28 pm
Still have to get the offroad tires mounted but here are the street users.
www.offroadohio.com
PostPosted: Wed Oct 27, 2010 2:21 am
Donnie hows it coming along? we'll be at clints fri nite camping till sun afternoon,,,bring it out!
