It is currently Sat May 02, 2026 6:25 pm
 Post subject: Stub Axles, Car to Bus
PostPosted: Thu Jul 15, 2010 11:30 am
Has any one machined off the lip of a car stub axle and redrilled and tapped it for a Bus CV?
I have done this with mine, and it works. I am wondering how a guy could go about puting on another
lip to help center the CV when you replace one in the woods.
PostPosted: Thu Jul 15, 2010 11:51 am
we build our on stub axles,put a car in a lay and take the whole cup off then put the bus stub in there and cut it off,then weld the bus to the car,its free and it works,jus gotta get them same length as a stock car stub
PostPosted: Thu Jul 15, 2010 2:03 pm
Sell you a set Troy.
Then you can see how it's done....... :mrgreen:
PostPosted: Thu Jul 15, 2010 3:08 pm
How bout you just send me some pics of them insted :mrgreen:
PostPosted: Thu Jul 15, 2010 3:39 pm
Sure......I have your CC number on file........ 8)
PostPosted: Thu Jul 15, 2010 7:24 pm
I have bus stubs drilled out to take car cv so I can use a car in a pinch
PostPosted: Fri Jul 16, 2010 6:51 pm
Now that's using your head
PostPosted: Sun Jul 18, 2010 9:03 pm
Hope your a great welder, thats alot of stress!!
Redrilling sedan for bus is really common. I've hade some with a ring welded on and seen lots that had no ring.
PostPosted: Sun Jul 18, 2010 10:03 pm
been running the same stub axles for 5 yrs,and we ride nearly every weeknd,and we do some ridin and playin,jus ask anybody that has rode her its some rough ridin,dammnit i hope u didnt jinx me,,gonna have to carry a spare now,,,lol
PostPosted: Mon Jul 19, 2010 11:27 am
Your using a bus torsion I take it.
PostPosted: Mon Jul 19, 2010 5:57 pm
Sorry :shock:
PostPosted: Mon Jul 19, 2010 7:32 pm
Not sure on torsions but arms r beefed up stock arms
PostPosted: Mon Jul 19, 2010 9:10 pm
Sounds like you have car stubs that were drilled for bus and a ring added. If your axle nut is 36mm its a car stub.
PostPosted: Tue Aug 10, 2010 8:26 pm
i used the car stubs that were drilled out i was not pleased with them the walls were too thin and even the one with a ring welded on the outside was week i kept shearing bolts off when i would get on it or the tire would take a jolt then it just started pulling the bolts out of the stub i think i just had a bad set though wasnt done correctly or something :roll:
PostPosted: Tue Aug 10, 2010 8:46 pm
yes
PostPosted: Wed Aug 11, 2010 10:27 am
I haven't had any problem with mine. I just would like to have some kinda ring around it, to make it easier lining up the bolts if I ever break a CV.
PostPosted: Wed Aug 11, 2010 12:09 pm
I've sold many sets of these and never an issue.
Sounds like your were made out of concentric.
PostPosted: Wed Aug 11, 2010 5:53 pm
well i seemed to have sorta called these shit and didnt realize i was just refferring to the set i had i know a few people that has ran these since i was little kid and still do to this day with out a problem sorry about that in a way i wish i had a set of these redrilled ones that were in good shape i had quite a few car cvs but gave them all away when i switched to the chromoly bus stubs
PostPosted: Wed Aug 11, 2010 11:39 pm
924/thing stubs also use 36mm axle nuts but have the bus pattern on them.
