It is currently Sat May 02, 2026 2:43 pm
 Post subject: my 2x3 arms build
PostPosted: Fri Apr 30, 2010 7:30 am
i finley got to start building my new arms its time to get this thing moveingImage
 Post subject: Re: my 2x3 arms build
PostPosted: Mon May 03, 2010 5:26 pm
thats sweet. Are you going to put anymore bracing in there? Kinda gets me motivated to start mine.
PostPosted: Mon May 03, 2010 6:10 pm
no i built a pair about 7 yrs ago just like these same jig never bent one or cracked one hit alot of trees sold them with my buggy had to build a new set for my baja
PostPosted: Mon May 03, 2010 6:27 pm
where you from?
PostPosted: Mon May 03, 2010 6:57 pm
im in indianapolis in
PostPosted: Mon May 03, 2010 9:21 pm
damn wish we were closer. Id rent that jig from ya.
PostPosted: Mon May 03, 2010 10:26 pm
blind chicken raceing shows and tells how to make a jig its real easy to make mine is made from scraps laying around the shop and you can make your own designs if i can help just hit me up
PostPosted: Sun May 09, 2010 4:41 pm
when you set the jig up, the arms are left or right correct? do you shim any angle into the bearing housing for any reason? just curious
PostPosted: Sun May 09, 2010 9:00 pm
i set the bearing housing at no angle at all and correct they are left or right i put mine on and set every thing level and the cv are at 19.5 degrese and are smooth jacked off the groundImage
PostPosted: Fri Aug 27, 2010 12:06 am
looks good alot of fing around to get to that ha good luck awsome baja
This one time at wellsville
