It is currently Tue May 05, 2026 1:53 am
 Post subject: oil cooler
PostPosted: Thu Apr 22, 2010 10:23 pm
What is the best external oil cooler to use
 Post subject: Re: oil cooler
PostPosted: Fri Apr 23, 2010 11:47 am
i usually run the black bugpack ones, but i have also broken lots of them. some due to mounting, some from stuff hitting them and at least one due to oil pressure.
PostPosted: Fri Apr 23, 2010 11:55 am
I like the mesa oil coolers. They aren’t flimsy like the cheap ones
PostPosted: Fri Apr 23, 2010 1:52 pm
Drews sells bugpack and they say mesa on them i think they are the same thing. Do you like the 72 or 96 plate?? and if you run a single stage pump like me do you add it in line with the pressure side or do you put in where the oil pump comes out of the motor????
PostPosted: Fri Apr 23, 2010 3:00 pm
I don't have a dry sump, so i have it located after the filter right befor the oil goes back into the engine. The one I blew up from pressure was a brand new engine that may have been shimmed a little too much. It also destroyed my autometer oil pressure guage (it tried to spin past the peg under 0) :mrgreen:
