It is currently Mon May 04, 2026 9:14 pm
 Post subject: cam question
PostPosted: Wed Apr 14, 2010 9:57 pm
I have a 2332 with a 125 ingle cam and was woundering if 1.25 rockers will help the bottom end power. the heads have had alot of port work to them and big valves
 Post subject: Re: cam question
PostPosted: Thu Apr 15, 2010 8:45 pm
i was hoping to get some input on weather this is worth the money and time
PostPosted: Thu Apr 15, 2010 9:21 pm
No it will not help bottom end cam is a little big. try small venturi & advance the cam 2 to 4 degrees & 6'' tall velocity stacks good luck.
PostPosted: Thu Apr 15, 2010 9:28 pm
Are you sure its a 125 thats pretty big cam. I dont think you will ever like it in the woods . JMO
PostPosted: Thu Apr 15, 2010 11:13 pm
when i bought the motor i was told it had a 110 cam. I pulled the oil pump to check the cam and found out its a 125. I already bought the rockers . They should be here fri. When i seen what size cam I kinda thought that might be why it s very slugish below 2 grand. will i see any gain if i change the rockers at all or is it a waste of time?
PostPosted: Fri Apr 16, 2010 8:28 am
its a waste of time if u want bottom end,would have to change cam
PostPosted: Fri Apr 16, 2010 5:39 pm
thanks for the help.
