It is currently Sun May 03, 2026 6:35 pm
Post new topic Reply to topic  [ 36 posts ]  Go to page 1, 2  Next
PostPosted: Sun Feb 28, 2010 1:06 pm
I fond this on ebay, what a great idea! Now we can put a tranny in that will hold the touqe of the suby and yes larger ac watchamacallits.
http://cgi.ebay.com.au/Reversed-Ring-Pi ... 0392967773
fresher ad
http://cgi.ebay.com/Subaru-reversed-tra ... 45f380cbc1
PostPosted: Sun Feb 28, 2010 1:31 pm
http://www.members.iinet.net.au/~ttriebler/
Found original website for these gears. They are a little expensive but hope more come along with a cheaper price.
PostPosted: Sun Feb 28, 2010 2:09 pm
How does that gear ratio compare to 6 rib? Looks like a great setup.
PostPosted: Sun Feb 28, 2010 2:12 pm
I'm dumb,,,do you need to flip the ring gear? Or does that engine need to run backwards?
never mind,, they answered it for me
http://www.members.iinet.net.au/~ttrieb ... age388.htm
PostPosted: Sun Feb 28, 2010 7:14 pm
for that much you can just beef up the stock trans.
PostPosted: Sun Feb 28, 2010 7:30 pm
But the automatic part would cost you extra
PostPosted: Mon Mar 01, 2010 8:28 am
They claim it will hold up to 650hp, You could never build a vw box to hold that kinda horse power for 1500 bucks.
PostPosted: Mon Mar 01, 2010 8:44 am
Replace your tired VW/Porsche 4 speed or 5 speed box with a modern synchromesh box with overdrive 5th and 265hp stock power rating this is the hp rating of ebay.
PostPosted: Mon Mar 01, 2010 9:41 am
Well, I'm sold!!! now we just need to find somebody to try it first.... 8)
PostPosted: Mon Mar 01, 2010 12:12 pm
lets get mikee........
- Sigmund Freud
- Antonio Meloni
PostPosted: Mon Mar 01, 2010 7:38 pm
Its basically stock suby internals then. I dont see a stock suby trany holding up to that kind of horse power. Also how many people do we have making that kind of horse power in there buggy?
Would be interested to see this in action though lol.
PostPosted: Mon Mar 01, 2010 7:52 pm
here my take on this. first off it is a rev. cut ring and pinion. thats cool. you have to do cut a releaf in the case to clear. no big deal. heres my point. you do not have to have the rev. cut to run them backwards. it the same. so why not try it with one you have lying around before you spend all that money. i know you would be running on the coast side of the gear. i have done that with vw trans when i was running corvairs and they lasted for a long time. so somebody try it. ill water jet the mounts with your help.
PostPosted: Mon Mar 01, 2010 8:06 pm
I looked around and these trans are not cheap ether.
PostPosted: Tue Mar 02, 2010 10:04 am
I know I could have got the trans for my motor for like $200 more than I paid. That is cheap!! what about drive flanges? How does the shifter input? I think I have seen close ratio gears for one around...
PostPosted: Tue Mar 02, 2010 10:19 am
As far as the HP 26[b] is the stock HP for the mottor I believe. It should handle more then that just like VW's.
I know the stock engine on a VW wasnt putting out close to what mine does and my 6 rib does fairly well with it.
PostPosted: Tue Mar 02, 2010 10:20 am
The Suby engine with Automatic would be a nice prospect for Babychains. The auto would take out some of the harshness of the drivetrain and the Babychains would allow for proper gearing. An auto shifter would be easy to fab too. With babychains you could build it midengine and save the extra cost of the reverse cut gears. I just wonder if the tranny could be upgraded like Mr. Burns does to take the abuse?
PostPosted: Tue Mar 02, 2010 11:14 am
What would it take to reverse the rotation of the engine? Just throwin around the idea. With newer engines you can change the firing order in the ecu along with the injection. the tricky part would be the cams. I would think you could send your cams out to a cam grinder, and have mirrored cams made (might not be tooo expensive?) Then figure out something with the oil pump, power steering pump and alt. Just an idea. :mrgreen:
PostPosted: Tue Mar 02, 2010 9:30 pm
Cam & seales for v8s
PostPosted: Wed Mar 03, 2010 12:59 am
you wouldnt even need ecu for that just switch coil wires and injector wires to suit..... done the same on the new chevy big blocks.... 2 hole are differ. fron the old big blocks
PostPosted: Mon Mar 08, 2010 12:12 am
You could adapt a honda engine to a subi trans to get the buggy to drive in the correct direction. There's an axle shop that will cut the subi inner joints splines onto VW axles. There's also some drive flanges that have subi splines and bus cv pattern. The downside is they are $550 a pair.
PostPosted: Wed Jun 23, 2010 12:39 am
Hey Guys, this is Todd here, the owner of http://www.subarugears.com Steve sent me an email enquiring about the boxes so I thought I'd get on here and see what sort of rigs you guys have and what sort of trails you do.
First off, I need to correct the post quoted above. You cannot just 'flip' the ring gear and pinion. If it was that easy everyone would have done it years ago. The design of the Subie trans is an 'offset hypoid' differential which is more compact and stronger than your regular bevel ring and pinion. However, this means that when you flip it, the gears no longer mesh because their angles are all wrong. This is why I had to go and get my own forgings done and cut the gears on a different angle, so that they mesh again once they are flipped. I went through all the other options, like running the box upside down and running the engine backwards but they were more expensive and worse solutions than doing the transmission properly. Also, most Honda engines rotate clockwise (same as all other engines) - it's only a few of the older smaller engines that rotate the other way. If you're after a modern, strong, efficient Honda it will rotate clockwise.
Stock Subaru turbo boxes will handle 265hp in a 4WD 3200 lb car so it's likely that in a 2WD lightweight buggy, say 1600lbs they will handle in excess of 530hp (theoretically). Wheelspin will most likely be your fuse, not the strength of the box. Aftermarket billet gearsets are available that hold 650hp in a 4WD 3200lb car so using that theory again, these should hold well over 1000hp in a lightweight 2WD buggy. I say all this "theoretically" because we have just got our test buggy on the road and are starting our test program with different trans options, ratios and power plants to see what works.
For you guys that are keen on the auto boxes, I have worked out how to reverse them, it will take me 6 to 12 months of R & D to complete and test it before releasing it. However a paddle shift 4 or 5 speed auto that can hold 1,000 hp easily in either 2WD or 4WD is a pretty awesome thought. It's a big box though, same length as the 4WD manual and quite heavy.
Anyway..... here's some info on our test buggy :
The test reversed 5 speed Subaru was fitted to a Sharpbuilt V2 buggy here in Sydney, powered by an EJ25 quad cam naturally aspirated. This motor puts out around 160hp standard. This motor runs a standard ECU and the transmission has been converted to 2WD and shortened so that it fits into the pan without cutting the torsion bar.
The box I built as a test transmission houses the original Impreza gears, the weakest gearset I can fit, just to see how it holds up in this application. The buggy is a LWB buggy which is licensed for the street and should come in just under 1000kgs (2100lbs) or so.
I used a Subaru cable operated transmission as opposed to hydraulic transmission just to retain the original clutch cable and bowden tube in the test buggy. I could have used a Subaru hydraulically operated transmission converted for cable use with my adaptor, but no need at this time.
We fitted a 3.9 final ratio reversed ring and pinion to this setup as it was the first one I produced, this is the standard WRX 2000 ratio. The owner of the buggy had wanted a different ratio more like 4.4 because of his tall tyres and sand dune driving.....but we needed to get this done and driving. More ratios will be trialled in this setup soon.
Here's the engine and box in place
The simple shifter connection, 2 tubes welded to 2 plates and bolted together
Here's how well it sits underneath, Subaru motor is fitted with a shortened sump
CV joint clearance to frame horns
The buggy was fired up and taken for a long drive around the block tonight. The owner commented to me that he was surprised that the 3.9 ratio seemed quite good actually, with 4th gear 60kph at 1600 revs.
He also commented that the cable clutch with bowden tube worked well and softly, no problems at all. He made some bowden tube holders to fit on top of the Subaru transmission as you can see from the photo.
The gearbox selected all 5 gears and reverse but he did comment that the sideways gate selection was shorter than his old 6 rib kombi box. Forward and backward was fine. We will try some different width plates and see if this makes the sideways movement to select gates a bit larger.
PostPosted: Wed Jun 23, 2010 5:57 am
Lots of good info! Thanks for spending the time stopping by the forums. Couple questions.
First with this trans and how low the the drive flanges are on the trans does this make the engine and trans sit higher then a stock vw would?
Also this is nice for you suby guys not having to buy an adapter plate but us ecotec guys would have to spend another $500 on another adapter? Or would we get lucky and be able to swap bells or have any other way of getting this to adapt to our setups?
PostPosted: Wed Jun 23, 2010 6:30 am
The engine sits 55mm higher with the Subie box than a vw box. It also sits around 30mm further forward than if using a 6 rib Kombi box. (if you have a Subie motor).
If you wish to use another motor you will need to use an adaptor plate, around 30mm thick because the flywheel is half covered by the transmission bellhousing and the subie motor bellhousing. So you'll end up the same distance backward as with the 6 rib Kombi and vw motor.
I am currently designing adaptors to mate the VW type 1 and type 4 to the Subie transmission, this consists of a crankshaft/flywheel adaptor to bolt the Subie flywheel and clutch on plus an adaptor plate.
If there are a good amount of ecotec powerplants out there I would be happy to look at doing the same for ecotec. If someone can give me the engine details (and preferable bellhousing and crank dimensions) we'll see if it can be done.
PostPosted: Wed Jun 23, 2010 7:36 am
Thanks for all your hard work and post,,,Please add your location to your profile so we know where you live. I wonder if a 4.86 ratio is feasible? Torsional input shaft? Close ratio gear sets? I hope you can do this and gain lots of strength and save the expense of buying the adapter. I run an eg33 and would like to see a suby tranny strong enough to handle our punishment but I may consider mid engine so the reversed R/P would not be necessary but converting to 2WD would. Which tranny and upgrades would you suggest for that application?
PostPosted: Wed Jun 23, 2010 7:54 am
Hey Firebug, thanks for the great comments.
There's no problems holding up to the power of an eg33, piece of cake. I would recommend the Subaru turbo box from 2000 onwards (the 8 bolt bellhousing). They will bolt straight up to your eg33 and include all the goodies such as wider gears, double synchros, revised oil paths and so on. Take a look at my website www.subarugears.com on the fully built transmissions page. I have a table where you can match up your engine/hp and vehicle weight and see what transmission we recommend.
Of course you don't have to purchase an entire reversed transmission from me, you can just get the r&p and your own transmission and do the mods.
P.s. I am located in Sydney, Australia. All my components are priced to include worldwide shipping to your door so don't let my location scare you. Complete transmissions are around $400 shipping to your door, a little cheaper if they take the slow boat.
4.86 ratio is feasible, I've got the engineers working on it right now to see if we can fit the teeth in that size housing. Close ratio gear sets are available too. Take a look at the reference page on my website, it lists all the gear ratio sets available in Subaru transmissions, so you can pick and choose.
Not sure I understand your statement 'I hope you can do this and gain lots of strength and save the expense of buying the adapter'. Also what do you mean by torsional input shaft?
