It is currently Sat May 02, 2026 9:51 pm
 Post subject: Which is better??????
PostPosted: Fri Aug 10, 2007 7:59 am
I'm gonna show my ignorance but I dont know anything about a six rib tranny I found two I am buying them together I just need a little help deciding which one is better, one is a nose shift and has 091 on it. The other has some kind of side shift deal on it.
Thanks, Rick
PostPosted: Fri Aug 10, 2007 10:47 am
Depends on which side shift you are buying.
Does the shift mechanism come out the intermediate housing or the actual center case section?
Like this one:
PostPosted: Fri Aug 10, 2007 10:55 am
The best I remember it was in the same area as the one in the picture. I really didnt know what I was supposed to be looking for.
PostPosted: Sat Aug 11, 2007 9:53 am
For ease of installation, most people use the nose shift style. The later side shift style like in the picture are stronger but the shift linkage has to be custom.
PostPosted: Fri Sep 28, 2007 8:18 am
If you get the side shift in the nose, (like I am), can you just swap out the nose from an older bus tranny to make it front shift?
PostPosted: Mon Oct 01, 2007 10:55 am
[quote='winifredevw']If you get the side shift in the nose, (like I am), can you just swap out the nose from an older bus tranny to make it front shift?[/quote]
You gotta use parts from the 091 six rib to do the conversion.
If you have all that you might as well use the whole 091 rather than convert.
PostPosted: Mon Oct 01, 2007 2:05 pm
The main thing is the intermeidate housing from a 091. They have not made any since 1979 so they are getting hard to find. You can buy the nose cone from weddle and they are working on the intermeidate housing.
PostPosted: Mon Oct 01, 2007 8:00 pm
Thanks for the replies, I'm kinda stuck with the '80 model, maybe I can cobble somthin' up.
PostPosted: Fri Nov 16, 2007 3:28 pm
i believe you can still get that intermediate housing from dave folts trans
