It is currently Sat May 02, 2026 10:52 pm
Post new topic Reply to topic  [ 56 posts ]  Go to page 1, 2, 3  Next
 Post subject: Torsion bars
PostPosted: Fri Dec 25, 2009 12:03 am
Say you want lift, so you twist up your torsion bars. Then it's too tight ,too hard of a ride. Take a high speed grinder and go around the bars in long passes.One row at a time. Try it . Too hard again? Spray paint them to know where you left off ,but then go down them again in LoNG thin passes again.(Type 3's are slightly fatter and I just click them once and you don't have to twist them as hard as Chineese arithmatic and they ride great with out grinding).Don't over do it.Buy something from Swayaway and you are stuck with it.I know, DD is an idiot, I should be shot in the face. Soft riding suspension and lite weight trailing arms absorbs the rocks and makes all the difference in competive climbing. Also shocks need to collapse fast and return slow.I spent days grinding my Bus torsions looking like Jonny Holmes to tote my HEAVY Buick 3800 softly. Oh yeah,ever had a buggy that would keep on sagging no matter what you did? The inner splinnes on the torsion tube aren't welded too solid. Had a guy throw away his frame because of that.
 Post subject: Re: Torsion bars
PostPosted: Sat Dec 26, 2009 1:52 am
:lol: :lol: :roll: :lol: :lol: :lol: :lol: :lol: :mrgreen: :mrgreen: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
Its no wonder you turned your back on anything old VW. You might have spent lots of money in the past trying to make VW stuff work, but apparently you dont even know the basic no-no's about it, and no amount of money will replace mistreating parts or installing them incorrectly.
I can see now why nothing VW ever held together for you. :roll:
I wouldnt advise even letting a torsion bar clang against something while its out of the housing.
PLEASE DO NOT DO THIS unless you want your bars to break in half inside your torsion.
PostPosted: Sat Dec 26, 2009 2:21 am
here we go again haha
PostPosted: Sat Dec 26, 2009 3:34 am
Nope, not arguing. Nothin to argue about here. DONT do it. plain and simple.
Bad advice causes SOO many people to give up on buggies, and VWs in general. Thats how VWs got a reputation on the street as unreliable and hard to work on because so many people worked on them that didnt really know what they were doing back in the day. Apparently the same applies to VW equipped buggies today. :roll:
PostPosted: Sat Dec 26, 2009 9:58 am
Now I don't know alot But back when I used vw stuff I turned my Torsion bars down careful to radius the ends ..it made all the difference in the world
PostPosted: Sat Dec 26, 2009 11:08 am
We put mine on a Lathe and turned them down to get rid of some weight. I think we cut them to 1/2". Shaved off 3 pounds. Made them flex real good also. :twisted:
PostPosted: Sat Dec 26, 2009 1:36 pm
Bruce you ain't right
PostPosted: Sat Dec 26, 2009 3:04 pm
Threw mine away. Went coil over instead.
PostPosted: Sat Dec 26, 2009 5:52 pm
I'm gald someone jumped on this. I couldn't find the right words.
PostPosted: Sat Dec 26, 2009 8:03 pm
LOL! Specially made bars to have a set spring rate and to perform this spring rate over and over again. Lets take a grinder to them! WAhooooo!!!! It will be like opening up a thing of biscuits. POP along the pre-cut lines.
Or buy coil overs.... :D
Boyd Jordan
PostPosted: Sat Dec 26, 2009 10:44 pm
Air bags work well too :wink:
PostPosted: Sat Dec 26, 2009 11:46 pm
A nick in a torsion bar can create a stress fracture and your grinding on them? :shock: :o :roll: :?: :!:
PostPosted: Sun Dec 27, 2009 12:41 am
You took the complete lack of words right out of my mouth. I have been here 3 times & just stared at it...
PostPosted: Sun Dec 27, 2009 1:18 am
Good to know I wasnt the only one that had to do a double take on this one.
PostPosted: Sun Dec 27, 2009 2:10 am
I bet if I staple emery cloth to a wooden dowel rod & chucked it in my drill I could line bore my block. I also think i can open up my case for 94's using my Dremel. Im going to torch the counterweights off an old Chevy crank & weld them on my 69mm crank myself. I think I can hand grind my flywheel down to 12 LBS. as well....Who needs a machine shop??? :shock: :shock: :shock: :shock: :shock: :shock: :shock:
Now if I can get my hands on some NITROMETHANE I think I can get that stock 1600 over a thousand HP on the dyno..... :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :!: :!: :!: :!: :!:
PostPosted: Sun Dec 27, 2009 2:14 am
Buggynut will you line bore my block for me now that your are pro?
Boyd Jordan
PostPosted: Sun Dec 27, 2009 2:40 am
Ill start taking orders after the holidays.....
OOOOOOOOHHHHHHH MYYYYYYY GODDDDDDDDD !!!!!!!!!!!!! Sorry for yelling I just had to let that out....
PostPosted: Sun Dec 27, 2009 11:17 am
I've done this, you don't even have to disassemble the block. :D Then I use a big hole saw on my heads.
1915 here I come :D
PostPosted: Sun Dec 27, 2009 11:25 am
Does this topic belong in Trash Talk?
PostPosted: Sun Dec 27, 2009 11:27 am
1915 here I come :D
OMG!!! Thank you....I was racking my brain trying to figure out how to open up the heads. I never thought about a hole saw.
PostPosted: Sun Dec 27, 2009 11:32 am
Im just grinding this topic like a stiff torsion bar......
& to think, I was speechless yesterday morning.....
I was thinking that after I run my belt sander over my case halves to give me a perfectly flat surface I was going to seal the cases with Bubble Yum.....pre chewed of course.....Im not an idiot aafter all.
PostPosted: Sun Dec 27, 2009 12:58 pm
LMAO! :D :D :lol: :lol:
Drilling holes in your wheel studs saves weight. About 10 pounds....
Buggynut can you just go ahead and cut my crank up and re-weld it so its a stroker crank?
:lol:
Boyd Jordan
PostPosted: Sun Dec 27, 2009 1:32 pm
:lol:
You must have very BIG Studs. We only got a 1/2 lb out of all of mine.
PostPosted: Sun Dec 27, 2009 2:05 pm
:lol:
Thats easy.....I just Sawzall the rod journals off & move em out a 1/4" or 3/8" & JB Weld em back on. This trick works up till you try to go past an inch. At that point you need to space the block halves apart with this nifty spacer I make from the recycled soles of Nike tennis shoes. Only Nike soles though.....Something in em makes them perfect for this application.
PostPosted: Sun Dec 27, 2009 2:33 pm
Posts
Amazingly
Stupid
Stuff
At
Times
What :?: :?: :?: Who said that :wink: :wink: :wink: I deny all knowledge :shock: :shock: :shock:
