It is currently Sun May 03, 2026 1:29 am
PostPosted: Mon Nov 30, 2009 10:17 pm
Does anyone have any 4 lug wheels they are looking to sell. I need something around 10 inches wide and would prefer to have beadlocks.
Thanks
PostPosted: Mon Nov 30, 2009 11:05 pm
good luck,,,u might have to make them
PostPosted: Thu Dec 03, 2009 10:17 pm
How about 5 lug wheels? Any recommendations?
PostPosted: Thu Dec 03, 2009 11:26 pm
I've got 4 lugs I'm willing to sell if I can find 5 lug alum w/ beadlocks.
PostPosted: Fri Dec 04, 2009 4:29 am
What do you have?
PostPosted: Fri Dec 04, 2009 12:18 pm
Steel 15x12 with beadlocks. But I have w5 rotors I want to put on it. Just need rims.
PostPosted: Fri Dec 04, 2009 8:40 pm
Sounds good, let me know when you are ready to talk..
PostPosted: Sat Dec 05, 2009 1:37 am
Here is what I have.
PostPosted: Tue Dec 08, 2009 12:18 pm
http://cgi.ebay.com/ebaymotors/BART-WID ... arQ5fParts
PostPosted: Tue Dec 08, 2009 8:39 pm
Are? those going to be strong enough? What thickness do I need?
PostPosted: Wed Dec 09, 2009 10:31 pm
I had the same thought. I like light weight but I do not want to bend a wheel.
PostPosted: Thu Dec 10, 2009 8:04 am
Firebug wrote:
http://cgi.ebay.com/ebaymotors/BART-WIDE-5-LIGHT-WEIGHT-WHEELS-15-x-10-5-OS-BEADLOCK_W0QQcmdZViewItemQQhashZitem33525ca207QQitemZ220425134599QQptZRaceQ5fCarQ5fParts
if these wheels are steel u aint gonna bend them,its hard to bend an aluminum wide 5
PostPosted: Thu Dec 10, 2009 9:13 am
You could save money by using 4 lug steel wheels and converting to beadlock. I would keep looking for some Aluminum beadlocks,,,you may have to settle for 12" wide,,10's are gonna be hard to find,,the wider tires will do better also.
PostPosted: Thu Dec 10, 2009 10:48 pm
heres a guy that has a few wheels
http://www.racingjunk.com/category/1155 ... PTERS.html
PostPosted: Thu Dec 10, 2009 10:52 pm
here is some more in lexington ky
http://www.racingjunk.com/category/426/ ... Model.html
PostPosted: Fri Dec 11, 2009 9:21 pm
After speaking with Nitro_Mudder today, I think I am going to build my own wheels. I already have 8 inch wheels and I am going to add steel beadlocks on both sides. The beadlocks should move my 8inch wheels out enough to fit 33X12.50 boggers.
Now I just need to buy the beadlocks. I was looking at Summit Racing. Any other suggestions.
Thanks
PostPosted: Fri Dec 11, 2009 11:29 pm
Was nice talking to you MM, glad I could help.
PostPosted: Sat Dec 12, 2009 2:38 am
Thanks
why would you want beadlocks on both sides, i guess u will put tubes to huh??after u do that ur wheels and tires will weight about 100 lbs a tire, u need to try and go lighter that big motor u have now is really gonna beat on ur tranny
