It is currently Sun May 03, 2026 10:54 am
 Post subject: porsche 914
PostPosted: Wed Sep 19, 2007 10:47 pm
found a porsche 914 with dual webers car is complete. is there anything other than the carbs any good on these i have intakes for type one. i can get it cheap . axles? cv's?
PostPosted: Thu Sep 20, 2007 4:14 am
Axles and CV's are worth getting as well as all the brakes. You could probably part out the motor and tranny to someone who still has one on the road.
PostPosted: Thu Sep 20, 2007 8:39 am
Plumberbill is looking for a type 4 motor, isn't that the samething? I'd agree on the the axles brakes.
PostPosted: Thu Sep 20, 2007 10:28 am
i'm still in the process of educating myself on the type 4 so i'm not sure about the differences between porsche t4 and vw t4. anybody with info please chime in.
- Sigmund Freud
- Antonio Meloni
PostPosted: Thu Sep 20, 2007 7:00 pm
My Dad is big into the type 4, but from what I have learned from him the porshe type 4 & VW type 4 are the same thing. We are going to put a 1800 cc (1.8 ) engine in my sons rail which came out of a porsche 914. I hope that helps . I think the old saying is true " there is no substitution for CUBIC INCHES ." I have a type 1vw engine built up to 1776cc, if you can start with a 1.8 (1800cc) your already past me and have'nt even had to build it up. Just some thoughts ????
Bruce
PostPosted: Thu Sep 20, 2007 7:52 pm
I thought so. but wasn't sure
PostPosted: Thu Sep 20, 2007 8:15 pm
I might need brake parts :!:
PostPosted: Thu Sep 20, 2007 8:40 pm
If you get it, I'd be interested in the front struts w/brakes. I'm using 914 struts cut down with welded in inserts for the front uprights on my baja.
As for the engine, 914s came with 1.7, 1.8, 2.0 type IV engines and a 2.0 911 flat 6. The type IV 2.0 engine has heads that are unique to a 914 type IV. The easiest way to identify these heads is they have 3 studs for the intake manifold instead of 4 as on the 1.7 and 1.8. All 914/4s were originally fuel injected in the US spec trim. Being as they were injected the camshafts aren't really optimal for use with carbs. Will it work? Oh yeah it will work just fine. I had a 2.0 Vanagon engine in my rail w/44idfs. It won't give you the most performance that these engines are really capable of. I had a 1.7 in my 914 that I had rebuilt w/86b webcam and raised compression ratio to 9.2. It was otherwise factory internally beside the melling oil pump. I had 2.0L heat exchangers and 44idfs. My 1.7 felt faster than my 2.0 in my rail. Heres two good places to find more info on type IVs/914s.
http://www.shoptalkforums.com
http://www.914club.com
John
PostPosted: Thu Sep 20, 2007 9:56 pm
I have a bud that runs a type 4 stroked to 2666cc......VW TORQUE MONSTER!
Where did you say the weenie trail is?
