It is currently Sat May 02, 2026 8:31 pm
Post new topic Reply to topic  [ 83 posts ]  Go to page 1, 2, 3, 4  Next
PostPosted: Sun Sep 20, 2009 7:30 pm
Here is what I started with, built for the sand. Light and FAAAAASSSSTTTT.
Some closeups
PostPosted: Sun Sep 20, 2009 7:32 pm
Here she is with a bumper, tree bars, and race brace.
PostPosted: Sun Sep 20, 2009 7:34 pm
Also Made beadlocks to solve the slipping problems
PostPosted: Sun Sep 20, 2009 7:35 pm
Since I have changed to Steel spindle fronts and now steel wide 5 fronts on drums and 3rib front tires to add weight. Now the front sticks to the ground alowing full use of right foot, woooooo hooooo!!!!
Also swapped out the Aluminum beam for an old spare steel one. Moved the battery up front. Found it was dead, lol, and replaced it.
That is the extent of my mods to date, will update as I get my butt in gear. Need to get the garage back in shape before s-10 geabox and brakes.
PostPosted: Sun Sep 20, 2009 10:20 pm
Nice build thread. Good pics!!
PLEASE X-brace that roof and main hoop!
PostPosted: Sun Sep 20, 2009 10:59 pm
Gotta finish my power steering and brakes. Next will be some extra bracing and a roof. Then rewire the main electrical system. I will have at least some extra added b4 D&K. Just in case :roll:
PostPosted: Sun Sep 20, 2009 11:16 pm
Got my mount done. Thanks troy for making me the plate!
PostPosted: Sun Sep 20, 2009 11:19 pm
Started in on the Pitman arm.
Round one, before I decided to extend it a few inches. Glad I only tacked it.
Here it is after making it longer with a slight raise.
And as I start adding extra strength. Image
PostPosted: Mon Sep 21, 2009 12:00 am
Almost forgot the tree bar extensions. Man I wish I would have added these sooner. My last trip to haspin was the only trip I've made where I didn't catch a small tree that hung me up.
PostPosted: Mon Sep 21, 2009 1:28 am
Ok ready to paint the Pitman arm now.
PostPosted: Mon Sep 21, 2009 7:32 am
looks good! how much does that steering box weigh??
lets just ride
PostPosted: Mon Sep 21, 2009 10:51 am
A ton, not sure exactly. Maybe 25 - 30 lbs.
PostPosted: Mon Sep 21, 2009 12:54 pm
Well all I have left to do on the steering is set up the steering shaft, mount the pump, and get hoses made. Luckily the pump just bolts on, direct mount, no belts, wooooo hoooo!. Now if only my frame wasnt an inch in the way, damn it! Oh well I guees it's surgery time. Just trying to figure out the strongest way to fix it. I assume its an area that needs strength. Gotta couple ideas, Ill look at it closer after work tonight.
PostPosted: Mon Oct 05, 2009 11:34 am
Well I got my Power steering setup installed last week. And I loved having it. Not sure it would help on a hillclimb contest Larry, but sure is nice on a hilly Trail ride. I'll get some pics posted later.
PostPosted: Mon Oct 05, 2009 12:09 pm
Your pitman arm is pretty but I broke one like that,,it is under a ton of stress,,might consider boxing it some,,maybe run an angle down it and run a bead down the angel for extra strength. good luck
PostPosted: Mon Oct 05, 2009 1:08 pm
Thats why I ran a piece of flat stock on top and bottom.Think I need more? I'm thinking of stealing a buddies idea and wraping rebar around it and welding it to it.
PostPosted: Mon Oct 05, 2009 2:43 pm
Sorry,,if I had paid better attention I would have seen that,,,after you welded it all up and ground it down smooth I could not tell,,,keep up the good work.
PostPosted: Mon Oct 05, 2009 3:31 pm
LOL, well Marty that was the idea! Whats ur opinion, need more?
PostPosted: Mon Oct 05, 2009 3:36 pm
:shock: Well, I didnt say nuthin, buddy! I wish everybody would get power steering, and run two of them pwr steerin boxes!! :mrgreen:
PostPosted: Mon Oct 05, 2009 3:58 pm
kybuggy1 wrote:
I know how to fix every p/s system perfectly........Take it off and sell it to someone with a 4x4 or CD. :mrgreen:
Yes I know you want everyone to have one! :mrgreen: But it was nice for bouncing accross roots, ruts, rocks and down trees without it jerking the wheels sideways. But then at around 1700 pounds mines more like a bobcat. Couple hundred pounds lighter then a bulldozer. :wink: And yes, I do read everything. :shock:
PostPosted: Mon Oct 05, 2009 4:06 pm
:lol: :lol: :lol:
You go that x brace in the rollbar yet? Halloween creepin up!
PostPosted: Mon Oct 05, 2009 4:08 pm
Not yet, but luckily I got laid off again on friday, lol. So plenty of time.
PostPosted: Mon Oct 05, 2009 7:47 pm
Got anymore vids?
PostPosted: Mon Oct 05, 2009 11:02 pm
Bout all I got at this point.
