It is currently Mon May 04, 2026 2:39 am
 Post subject: front trail arm
PostPosted: Sun Aug 16, 2009 9:06 pm
my front tailing has some slack in it. i was was thinking my bearins might be busted but they look fine, looking in the tube. if yall think thats the promblem . how do you replace them?
 Post subject: Re: front trail arm
PostPosted: Tue Aug 18, 2009 12:21 pm
Its easiest to get the full legnth red bushings. I don't really like 'em, but good luck putting the stock bearings back in a beam thats seen the woods!
PostPosted: Tue Aug 18, 2009 1:48 pm
My last beam was egged out on the lower tube where the outer bearings go, causing the lower arms to move.
PostPosted: Wed Aug 19, 2009 10:39 am
THANK YOU, so how do i get the bearings out so i can use the polly bushing?
PostPosted: Wed Aug 19, 2009 11:04 am
I used a slide hammer to pull mine out and it worked great.
PostPosted: Wed Aug 19, 2009 1:16 pm
go from the oppisite end with a piece of small tubing and jus drive them out,i think on my balljoint there is a clip that holds them in
