It is currently Sat May 02, 2026 8:40 pm
 Post subject: Subi Fuel tank
PostPosted: Wed Jun 10, 2009 7:57 pm
I am converting my VW engine to a Subi engine and I had a question about my gas tank. I currently have a spun aluminum round tank. Can I modify my tank to work or do i need a new tank with a return.
I have also read about running a small reservoir below an existing tank. Will that work?
Thanks
 Post subject: Re: Subi Fuel tank
PostPosted: Wed Jun 10, 2009 8:09 pm
You need to nothing except some fancy plumbing. Toooooo easy. I'll see if I can find the info for you.
Look here ----> http://woodsbuggy.com/forum/phpBB2/viewtopic.php?f=17&t=3648
PostPosted: Wed Jun 10, 2009 8:30 pm
That's the one.
PostPosted: Wed Jun 10, 2009 10:20 pm
I use the spun 10 gal aluminum with fancy plumbing work, works good!
PostPosted: Thu Jun 11, 2009 12:51 am
That sounds too easy to be true. I sure am glad I asked before I started modifying the tank.
Appreciate the help. One more thing off the checklist before I pull my VW engine.
PostPosted: Fri Jun 12, 2009 9:22 pm
MM I thought we hashed this out at Turkey Bay and decided you would not do this !!!!!
Just kidding we will be waiting on pics and updates !
PostPosted: Fri Jun 12, 2009 9:38 pm
It is Firebugs fault.. He made it too appealing with a 2.2 subi ready to install.
Just kidding... The main reason I am converting is so I can pass my yearly emissions test. The VW engine does not stand a chance and I am tired of paying $700 each year for a waiver.
I must say, I am a little nervous. My 1835 has never let me down and I am not very knowledgeable about the subi engines. I hope they are as reliable as everyone says.
PostPosted: Fri Jun 12, 2009 9:48 pm
I am going to lean on your opinion once its done . I thought about putting one in Angie's buggy to try one out .
Have you already started the actual swap ?
PostPosted: Fri Jun 12, 2009 10:03 pm
Nope, I am waiting until after the ride next weekend.
PostPosted: Fri Jun 12, 2009 10:58 pm
This my 4th year with the same motor. Runs as good today as it did when I put it in.
