It is currently Sat May 02, 2026 11:49 pm
 Post subject: My Bada** buggy
PostPosted: Thu Apr 30, 2009 5:34 pm
Well, ive had no takers on my buggy. Lots of lowballers of course. So this is one last post before i part it out. Someone make me a resonable offer or its getting parted out.
Thanks woodsbuggy for all the info in the past.
Nick
 Post subject: Re: My Bada** buggy
PostPosted: Thu Apr 30, 2009 5:37 pm
Mabey its a hint to keep it! But if you have to part it out I'd be interested in the half shafts, for the right price that is.
PostPosted: Thu Apr 30, 2009 6:00 pm
I might be interested in the wheels if you part it. If you decide to go that route send me the dimensions including backspacing.
PostPosted: Thu Apr 30, 2009 8:09 pm
Fronts are 15x5 with Maxxis mudders buckshots 245/75/15 i believe regular offset
Rear are 15x12 minimum offset like 3.5" with Boggers 31/12.5/15
Everything is all brand new never ran or cut
And the half shafts i paid $1600 for them there also brand new and jet or ceramic coated 930 setup
I have no choice but to sell it. My ole ladies laid off im getting my hours cut and family comes first.
PostPosted: Thu Apr 30, 2009 8:13 pm
Rims and Tires
Douglas 15x5 Front rims w/beadlocks Maxxis Mudder buckshot tires 235/75/15
Douglas 15x12 minimum offset rear beadlock rims w/Boggers 31/12.5/15
Shocks
Front 2- Fox Shox Coil-over w/reservoir 12 inch travel and hypercoil springs
Rear 2- Fox shox Piggy Back reservoir with 18 inch travel and hypercoil springs
2 front shock billet spring dividers
2 rear shock billet spring dividers
4 billet shock reservoir tube mounts
2 Fox bumpstops with mounting sleeves
2-24” limit straps
2 spring loaded limit strap mounts
Seats
2 Corbuea with chrome belt hoop inserts
2 sets of Crow 5 point harnesses with crotch strap
Brakes
Front Pro-am sportsmens hubs w/ 2 piston calipers and vented rotors
Rear Gear-one micro stub set up with 4 piston calipers
Eagle performance front beam with long travel coil over shock towers
Front Eagle performance front trailing arms 4x1.75 woods spindles
Rear Eagle performance 4x5 trailing arms w/micro stub set up, shock mounts and inner pivots
Pedals
CNC Throttle pedal w/foot rest
CNC dual tall reservoir w/quick cap brake pedal ¾ bore
CNC single reservoir w/quick cap clutch pedal ¾ bore
CNC slave cylinder w/slave saver kit (blue)
Billet sliders for all pedals
Summit 12 gal fuel cell with foam baffling (aluminum)
Steering
Grant steering wheel w/horn and quick disco
Tilt steering box
Power steering
Sweet servo
Howe ram
Howe pump w/pulley
Pro-am power steering reservoir w/filter
Misc. steering shafts and U-joints already together (sweet)
Heavy duty tie rod w/high misalignment hiems
Saco heavy duty magnum rack
Misc power steering and hydraulic lines and fittings
Guages
Autometer 2” Gas guage
Autometer 2” cylinder head temp
Autometer 2” oil temp
Autometer 2” oil pressure
Autometer 2.5” Voltage guage
Autometer 3.5” speedometer and sender
Autometer 2” Gas guage w/sender
Pro-Comp 6834 monster tach fully programmable
Aluminum Radiator
Chrome radiator overflow
Chrome radiator flex hoses with ends
Misc.
4 chrome front beam mounting brackets
2- 1.5” billet tube ends or end caps
Chrome battery box (summit)
Braided brake and clutch lines
36” line stainless braided
30” stainless braided line
2 42” stainless braided lines
2 84” stainless braided lines
114 stainless braided lines
6 mini lazer star lights w/caps
Misc. tabs and gussets
Interior
2 Oh shit grab bars billet
1 adjustable oh shit bar billet
1 billet foot rest bar
1 double rise aluminum center console
1 billet switch box
Transaxles
091 Don Johnson built bus box with stargazer powder coating
Pro-am shifter very nice
091 case empty
Kennedy stage 2 clutch w/kushloc disc and heavy duty throwout bearing
Chrome hi-torque starter
Frame
Berrien Venture frame with custom torsion, custom tranny upper and lower mounts, diamond tread floor with wing trunk.
Motor
2.5 Outback built Subaru
Pierburg super quiet fuel pump and secondary filter
Stinger EMS computer
New wiring harness (nice)
330 HP
Every bolt on available except scoop.
K+N breather system
All AN lines and fittings.
So thats what i have to sell
PostPosted: Sun May 03, 2009 1:53 am
Anyone wanna make some real offers?
PostPosted: Sun May 03, 2009 4:56 pm
is the switch box made for the roof?
interested in it and gas and speed gaugeswith sendin units
mayb all the gauges 4 right price
PostPosted: Sun May 03, 2009 4:57 pm
friend of mine interested in wheels and tires what lug pattern r they
how much
PostPosted: Sun May 03, 2009 10:34 pm
PM sent
PostPosted: Mon Jun 08, 2009 3:30 pm
what do u want for the 2 buckshots or boggers
PostPosted: Mon Jun 08, 2009 4:18 pm
I am interested in the 235/75/15 front tires. Are they on a vw wide 5 pattern? How about pming me a cash price for the tires?
cron
