It is currently Mon May 04, 2026 2:55 pm
Post new topic Reply to topic  [ 135 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 Post subject: Re: Predator 4 seater
PostPosted: Tue Jan 27, 2009 7:33 pm
nickschlemer wrote:
What are those front trailing arms. They look sharp..
Tweeds 4"longer x 1-3/4 wider http://tweedsdesigns.com/products.htm
PostPosted: Tue Jan 27, 2009 9:59 pm
Good upper limit stop. The red is a rectangular pro-thane bushing 1 x 1 x 1 1/2, or something like that. Works well on my set-up.
PostPosted: Tue Jan 27, 2009 11:49 pm
i need some of those red stopers where did ya getem
PostPosted: Wed Jan 28, 2009 6:17 am
That simple enough. Thanks MM.
PostPosted: Wed Jan 28, 2009 4:13 pm
I got mine from my local Murray's Discount Auto Store. They were energy suspension and had them on the shelf for less than $15. Summit, Jegs, and ebay all have them, just search bump stops.
PostPosted: Wed Jan 28, 2009 5:36 pm
Thanks Brad, can't rermember where I got mine. Jim's Custom VW I think.
PostPosted: Sat Feb 07, 2009 8:57 pm
One of my new trailing arms...
I pulled my tires out too, 33x12.50 boggers. I bought them cut like this but may do some more trimming.
PostPosted: Sat Feb 07, 2009 9:18 pm
don't let that guy cut no more tires :shock:
PostPosted: Sat Feb 07, 2009 9:20 pm
Might I enquire where you got the rear trailing arms?
When in doubt, Hold it to the floor and hope for the best!
PostPosted: Sat Feb 07, 2009 9:44 pm
He did no damage... He could have saved alot of time with a different blade.
PostPosted: Sat Feb 07, 2009 9:45 pm
A buddy built them.
PostPosted: Sun Feb 08, 2009 8:51 pm
you better beef up them arms or thay wont last long!
PostPosted: Sun Feb 08, 2009 9:21 pm
I'm confident they should hold up. The first trial of this arm was made out of electroweld 1-1/4" .095, riden hard and even raced. These are DOM .095 1-1/4". Time will tell.
PostPosted: Wed Mar 25, 2009 8:43 pm
Its a roller!!! I'm going the cut the race brace out and re-do it, and I need to move the transaxle back about 2 inches. I've got my 23" axles in the mail and new BTR beadlocks :D I think were going to dimple die the trailing arms in too. Image
PostPosted: Wed Mar 25, 2009 11:03 pm
lookin good!!!!
PostPosted: Thu Mar 26, 2009 7:33 pm
man that thing has some serious ground clearance
Awesome work !!!
PostPosted: Mon Mar 30, 2009 9:18 pm
how wide is the back of that dude ?
PostPosted: Mon Mar 30, 2009 9:31 pm
TBD... as it sits its 85". Thats part of the reason I'm getting some new wheels. I've got som BTR's in the mail. The current steel wheels ar 10" with 2" backspace. I've seen 33-12.50 boggers on the 7" BTR's, after I mount one I'll see If I need to go with 33-10.50 boggers. I should be in the 80-81" range. Also, Its 110" wheel base right now.
PostPosted: Tue Mar 31, 2009 7:51 am
The backspace on the BTRs isn't a whole lot better. I think they have a 2.5" backspace. Lookin Good! That shock boss looks familliar! :mrgreen:
PostPosted: Tue Mar 31, 2009 8:19 pm
2.75" backspace isn't much better but the wheel beeing thinner should help too. And thanks for the shock boss in a pinch!!! I just got some shipped to me today to get you hooked up. The front air shocks are going to need more than 200psi... I'll have hook you up with some bud light in trade for more nitrogen :D
PostPosted: Thu Apr 02, 2009 7:44 am
Want to go for 300lbs?
PostPosted: Thu Apr 02, 2009 8:53 am
Very nice!! Thanks for postin.
Bryan
PostPosted: Thu Apr 02, 2009 8:41 pm
I started with 300# in my front shocks and it wouldn't budge. If you go with 300 be prepared to let a little out. I would try 250. My shocks are 12" if I remember right. Buggy looks really good.
PostPosted: Fri Apr 03, 2009 1:48 pm
I don't claim to know much about the air shocks, but doesn't the oil level also assist in the "spring rate" or is that more about the dampening? I believe acole has the same front arms as you (40 deg), so in a perfect world, the same pressure would have the same results. If it were only that easy :?
PostPosted: Fri Apr 03, 2009 6:34 pm
The oil is the dampening and the nitrogen is ride height, so they say. I had my shocks fully extended and added 300# and after fighting to get them on the car the front end wouldn't budge. I would have to check to see how many cc's of oil I filled them with. I just tapped the schrader valve until i got some movement out of the shocks. I have a long way to go to get them right. I haven't driven the car yet either so some heat and movement may help losen them up. Yes, we do have the same front arms.
