It is currently Sun May 03, 2026 10:16 am
 Post subject: 091 mods on a budget
PostPosted: Sat Feb 14, 2009 3:32 pm
I have a super diff and an 091 from a watercooled with the side shift. I would like to at least have the super diff put in for now. What else can I have done now on a budget without replacing all the gears with weddle. I just don't have a couple grand to spend after the powder coat and all. I need bang for the buck, any recommendations?
 Post subject: Re: 091 mods on a budget
PostPosted: Sun Feb 15, 2009 2:22 am
you already did it. next is weddles :)
"Lets go get stupid"
PostPosted: Sun Feb 15, 2009 9:46 am
The super diff is about all you need for now. There is one mod you could do to make it shift better. There is a tension spring on the driver side of the trans that can be removed. Its under the 3 bolt housing opposite the shift arm.
PostPosted: Sun Feb 15, 2009 11:14 am
Turboblue told me about the spring on the reverse switch. I guess the linkage slides better with it removed. Thanks, I guess for now I will just have the superdiff installed. Anyone local to the Dayton/ Cincinnati Ohio area that wants to put in a super diff? I will try to build or repair about anything but transmissions have always made me nervous. I have plenty of other things to work on to get this project done.
PostPosted: Mon Feb 16, 2009 5:37 pm
if I can put a superdiff in you can! very easy to do just remove the bearing collets on the sides, remove ring gear, reinstall ring gear then put it back in. make a mark on the collets when removing them then count the turns out on both sides then when putting it back in you can get it very close.
PostPosted: Mon Feb 16, 2009 11:18 pm
Well if its that easy maybe I'll rip it apart and try it. I have to put 930 flanges on anyway.
PostPosted: Tue Feb 17, 2009 8:33 am
you should also get a chrome moly pinion nut, cheap insurance.
PostPosted: Tue Feb 17, 2009 3:18 pm
Piece of cake to install a super diff. You can call me and I will be glad to give you some pointers or walk you through it. It's really not difficult. There are things you need to know to do it 100% correctly.
PostPosted: Fri Feb 20, 2009 6:18 pm
Call Brian DREW at 1-888-463-7397 .You well need to set the back lash .Run it tite for the woods & lusser for road.
PostPosted: Sat Feb 21, 2009 10:25 am
yea if you mark it and count you can get it back really close then just feel with your hand. it should have just the slightest amount of play.
PostPosted: Sun Feb 22, 2009 11:52 am
buy a cheap dial indicator......
PostPosted: Sun Feb 22, 2009 9:45 pm
.004 to.005 for the wood .007 to .008 for the road . .004 well get hot on big road trepp.
PostPosted: Mon Feb 23, 2009 9:24 pm
if you have'nt alreay done it i would be happy to help you out,i don't want any money or anything.i'm just a little south of Dayton.It would take less than an hour if you had the bellhousing off and everything was clean.i have the special socket it takes to get the side cups out so that makes the job a little easier.let me know if i can help.Aaron
PostPosted: Mon Feb 23, 2009 11:51 pm
Sent you a PM Aaron, I would really appreciate the help just to see it done correctly.
PostPosted: Tue Feb 24, 2009 10:32 pm
I got the superdiff in today! I just got nuts and went at it. I marked the thrust retainer things (whatever you call them) and the case with a punch and just counted the rotations. I made my own tool with a piece of tube that was about the same diameter as the I.D of the retainer. I then welded 3 beads on the tube and ground them to a point until the fit pretty snug in the retainer. A couple taps with a mallet and they came loose and I just backed them all the way out. I didn't buy a gasket for the bellhousing I just used some RTV silicone. Everything seems to turn smooth and it looked good inside with just a few small metal shavings. This was easy but I think I will leave the Weddle gears and rebuild to the pros when it comes time for it. Thanks to everyone for the help.
PostPosted: Wed Feb 25, 2009 1:23 am
yea the rest no touchy haha least for me.
PostPosted: Wed Feb 25, 2009 7:31 pm
I never use silicone on mine i use indian head gasket glue then take brown bag or the brown paper like you get at the hardware store,even used the brown bag out of the inside a dog food bag once but never silicne.thats stuffs hard to clean out or off of anything.ive never had them to leak and can take them back apart and sometimes get to save the gasket and use it again.just put the gasket glue on one side only. :mrgreen:
