It is currently Sun May 03, 2026 2:27 am
 Post subject: 3.1 Chevy V-6
PostPosted: Sat Feb 21, 2009 9:42 am
Well a friend has a 3.1 V-6 from a Chevy EFI. He thinks he needs a turbo :shock: Any one have a web page or info on this?? If you have this set up did you use the factory computer with or with out mods? Or ??? Thanks Dave T
 Post subject: Re: 3.1 Chevy V-6
PostPosted: Sat Feb 21, 2009 2:58 pm
Fox, Curt's dad Bernard has one that is turboed with PROPANE. Advantages = 103octane, no sensors needed, no wiring, no fuel pump, no fuel spillage (when you are upside down!). You can even run a simple draw through setup. Unlike gasoline, propane will not pool up in the turbo on a draw through. Propane has a very wide range of lean to rich tolerance. Motor will stay cleaner. No gunk on intake valves. No carbon on pistons. Oil last twice as long. Hope this helps.
PostPosted: Sat Feb 21, 2009 7:55 pm
propane's for cooking
PostPosted: Sat Feb 21, 2009 10:18 pm
We got cat alturdyne motors at work that run on propane. Theyve been burning through a gallon of antifreeze every two weeks. And let me tell you that will make some build on your pistons real quick.. Anyway propane in the thread got me thinking about work something i hate to do when im not htere.
PostPosted: Sun Feb 22, 2009 12:59 am
OK, Then; am i missing something? Isn't there a big red buggy (Curt's buggy)in most of the videos, climbing most of the baddest hills? What fuel does it use? PROPANE! IMHO.
PostPosted: Sun Feb 22, 2009 9:05 am
thats cause some times we stop on the trail and cook hot dogs so we need the propane to cook the dawgs
PostPosted: Sun Feb 22, 2009 8:49 pm
charcoil is for cooking,,the only thing propane is good for is cooking hotdogs on curts buggy,,,lol
