It is currently Sun May 03, 2026 10:13 am
PostPosted: Thu Jan 15, 2009 9:52 am
Looking to make this modification over the next 3-4 weeks. How difficult is this? I have rebuilt auto trannies and rear axles before. However, haven't been inside a vw tranny....yet.
Thanks in advance.
PostPosted: Thu Jan 15, 2009 4:01 pm
It's easy. I'm not too sure on the adjustment of the backlash, but it is not difficult. You will need the 091 screw in adjusters and new bearings.
PostPosted: Thu Jan 15, 2009 6:53 pm
Cool, where is the best place/price to get the parts and pieces from? Thanks.
PostPosted: Thu Jan 15, 2009 8:01 pm
Weddle Ent. offers this as a "kit". Everything you will need to install a 6 rib dif into a 002 transaxle. The job is very straightforward. Not difficult at all. You will need a special tool to unscrew/tighten the side adjuster cups. You can make this tool if you are a crafty guy. :|
PostPosted: Thu Jan 15, 2009 8:07 pm
I made my tool to adjust the bearings from a part I cut off of a factory trailing arm,,you know that square thingy that the bottom shock mounts to., I had one I cut off and just kinda reshaped it a little so it acts as a huge socket. :wink:
PostPosted: Fri Jan 16, 2009 8:55 pm
Heres a couple pics of a homemade 1 to give you an idea how easy it is to make,
PostPosted: Sat Jan 17, 2009 2:05 am
Thanks for the replies. Since I dont have any other trailing arms to modify, I guess I'll have to make one. Looks like I will call Weddle come Monday.
PostPosted: Sat Jan 17, 2009 2:51 am
I did close to the same thing. Took a large socket and welded two beads down the side. Works like a champ.
This is the correct tool if you want to spend big money.
PostPosted: Sat Jan 17, 2009 10:15 am
Long transaxle has these tools in stock. They are good folks to deal with. They also have the pinion nut socket you will need. Go ahead and spring for their how to rebuild cd. Its very good. It has a complete step by step teardown and rebuild along with what to watch out for. It also has all the specs. Make sure you get a depth micrometer and measure the side adjuster depths as well as scribe them for location. If you don't do that, you will have a huge headache setting up the backlash and getting the bearing preload correct.
John
PostPosted: Sat Jan 17, 2009 4:21 pm
I have the correct socket now but in the old days I used this tool that I made. It works great too! I gave it to Odynuck to use a while back.
