It is currently Sun May 03, 2026 11:30 am
PostPosted: Mon Oct 27, 2008 1:11 pm
Just want some opinions, Im running an 1835 with a 3 rib bus, tranny needs redone, and I would like a little more speed 1st gear is to slow on the long climbs any help would be greatly appreciated thanks. Also any places in ohio that I could take it to for the rebuild?
"IT IS WHAT IT IS"
PostPosted: Mon Oct 27, 2008 5:34 pm
Water-cooled Vanagon.
Most have 4:86 R&P.
Strongest VW based tranny in stock form.
PostPosted: Mon Oct 27, 2008 7:07 pm
A 5 rib bus trans would be what the doctor ordered for you. Has the 4.86 ring and pinion to give you more speed in first and it still has the nose cone shift so it will be a direct bolt in deal. They are getting hard to find but worth looking for. Should hold up fine to an 1835.
PostPosted: Tue Oct 28, 2008 12:22 am
I'll have to agree with what has already been said,a 5-rib or the side shift 6-rib is just what you need.If you still want to rebuild your current trans I can help you out if your local.Where in Ohio are you?
PostPosted: Tue Oct 28, 2008 7:56 am
I ran a 5 rib with a 6 rib diff for a couple of years, worked real well til I broke it showin off. Go figure. :wink:
PostPosted: Wed Oct 29, 2008 7:14 pm
im in randolph, portage county
"IT IS WHAT IT IS"
PostPosted: Tue Nov 11, 2008 12:09 pm
The right answer is a 5 rib with a 6 rib diff. but what most people don't know is that the main gears in the 3 and 5 rib are all the same. so all you have to do is put a 5 rib ring and pinion which is 486 to 1 on a 6 rib diff carrier which has 9 tooth spder gears that are stronger. There is a shop that specializes in bus tranys only in Shadyside Ohio called BT Offroad. I could find their number if you like!!!!
Jim
PostPosted: Tue Nov 11, 2008 6:53 pm
Most water cooled vanagons are 4:86 with the 091 style diff and a killer reverse all it one package.
Just have to buy or fabricate the shift linkage, no big deal.
To clarify the gearbox gears statement, the early 3 rib gears were the same as a sedan transmission.
The good 3 rib gearbox gears didn't come along until '72 if I remember correctly.
Then they were only in the 3rd generation '72-73 model year 3 rib.
Early acorn nut '68 3-ribs were the 1st generation.
Late '68 through '71 was the 2nd generation 3 rib.
5 rib came along in '74 &'75.
091 6 rib were 76-79
