It is currently Mon May 04, 2026 8:01 am
 Post subject: powder coat
PostPosted: Tue Oct 07, 2008 6:54 pm
anybody have a ball park figure of how much it cost to powder coat a frame ?
 Post subject: Re: powder coat
PostPosted: Tue Oct 07, 2008 7:09 pm
there is a place in Huntsville,Alabama called "its not paint" said $600 that was about a year ago i dont imagine it has went up much
Phillip
PostPosted: Tue Oct 07, 2008 7:27 pm
Clayton Hollingsworth "AKA" Hollywood does powder coating in London,KY and he did a frame for me a couple yrs ago for$300.Dont hold me to that price though,but he is good and fair on his prices.Send me a PM and i'll give you his # or you can call Tim at Southern buggys aat 606-864-2217 for his # as well.
PostPosted: Tue Oct 07, 2008 7:47 pm
I paid $375 to have mine done 4 or 5 years ago, Gloss Black with a clear coat.
PostPosted: Tue Oct 07, 2008 8:19 pm
make sure you clear coat it makes it tuff some times if you buy your own powder it makes it cheeper
PostPosted: Tue Oct 07, 2008 8:23 pm
I might be wrong.. but it is my understanding that once you powder coat the frame. It is difficult to make any modifications and add additional tubing.
PostPosted: Tue Oct 07, 2008 8:52 pm
Well, its not much differentthan paint in that matter. Grind a bare spot to weld. Its just a bit more work to patch back up. My buddy with powdercoat has found a rattle can that matches his color. But it defeats the main purpose of powder coat.
PostPosted: Tue Oct 07, 2008 8:56 pm
Not difficult at all. Proper weld prep and a good rattle can paint job when your done. I have added to or altered my chassis a bunch since it was coated. I glad I did it in black, makes the color match easy.
PostPosted: Tue Oct 07, 2008 9:02 pm
Well, its not much different than paint in that matter. Grind a bare spot to weld. Its just a bit more work to patch back up. My buddy with powdercoat has found a rattle can that matches his color. But it defeats the main purpose of powder coat.
The main purpose is to protect the frame from rust. If you add or fix something, there is still 99% of it coated.
PostPosted: Thu Oct 09, 2008 10:49 pm
Mine was done at Rack Coatings in Cannal Fulton, OH a long time ago. Price then was about $400 and it had to be sandblasted first. I would not do it again on a buggy. It will last forever if you never have to repair a tube or make any frame mods, it can also hide dangerous frame cracks! I will use paint on my next build. On the other hand though, pwder can be touched up years later with another light coating of powder and baked again. It can be done in any color for duability but the color must be the same to get any good looks from it. Be careful of who sprays the powder. Powder is expensive and a little goes a long way. Unlike paint, too much powder does not run. It just spreads out and looks good but kills your wallet.
PostPosted: Fri Oct 10, 2008 1:42 pm
Have you actually tryed to redo powder coat on a frame repair with out being able to put the whole frame in a 400 degree oven for an hour.
PostPosted: Fri Oct 10, 2008 5:33 pm
iv seen it done with heat lamps befor
PostPosted: Tue Oct 14, 2008 8:51 pm
No, did not try to recoat. Rack Coatings offered to try and blend in some frame changes I made after the original coating. The changes were some high repair items so I chose to blend paint into the powder. The recoating plan is surely a winter project that involves a complete tear down and recoating of the frame...just like the original coating without the sand blast. My current employer uses powder coating every day...the oven is just not big enough for a frame. :( Anything smaller than a frame would fit in our oven but the bosses might question why I was spending 40hrs a week in the coating shop! I do like my job so I will keep paying for paint and powder.
