It is currently Sun May 03, 2026 9:21 pm
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
 Post subject: Re: BOTM August 2008
PostPosted: Fri Aug 15, 2008 1:21 am
no problem 8)
"Lets go get stupid"
PostPosted: Fri Aug 15, 2008 8:48 am
Hey Ody,
Was wondering about your winch. Looks like it's mounted on a receiver and can be moved around. Are you happy with your set up? Any changes you would make? Are there any close up pics of the mounting bracket? Was wiring a hassle? Sorry for so many questions but I am liking the idea of having a winch.
Thanks
Bryan
PostPosted: Fri Aug 15, 2008 9:22 am
Bad Influence wrote:
Hey Ody,
Thanks
Yes it is designed to be used in the front and rear of the Buggy. I used the standard 2" reese trailer hitch setups. It stores in the top of the front hitch for protection. When I need it I either slide it into the the front pocket in front of the Bumper or in the rear cage area. The wiring is not bad. The Warn 4.0 winch comes with a relay and remote controller. Locate the relay close to the battery and run a pair of # 8s minimum to each location. The kit comes with enough cables to do the battery and one hitch location. I have pics of the mount however they are way to large (2 meg) to post here.
PostPosted: Fri Aug 15, 2008 9:45 am
Hey Ody,
Thanks
Use this to reduce the size of those pics Steve.
http://www.irfanview.com
