It is currently Sun May 03, 2026 3:56 pm
 Post subject: Pulling double trailers?
PostPosted: Fri Feb 22, 2008 11:54 pm
I didn't want to hijack a thread so I thought I would start this to ask what the laws are regarding double trailers. I have a 30' bumper pull camper and would like to pull the buggy behind it on another trailer. I pull with an F-350 with a 9' dump. It's just a typical contractor small dump. My buggy is about 16' long. I would need to measure the truck. The camper length includes the tongue length. I don't even know if its legal to tow doubles like this or any length requirements. The camper and buggy trailer would total around 50'. The truck has to be around 17' so I'm pushing 70' total.
PostPosted: Fri Feb 22, 2008 11:58 pm
I dunno, that is pretty long combination, you know how Ohio is, they are pretty tough on traffic laws. That would work if you can get by with it.
PostPosted: Fri Feb 22, 2008 11:59 pm
I have seen several people pulling dual trailers but I can't help with the legalities of it. Check with your DOT office and ask them for a ruling on it. With it being that length or close to it would seem to be considered for some load escort or something if it was commercial I would say.
Seems like this came up on another board Dodgetalk.com about a year ago. I will look and see what I can find for you.
Good luck on the search.
The Wild Kids
PostPosted: Sat Feb 23, 2008 12:34 am
I know in MI the first one has to be a 5th wheel type
PostPosted: Sat Feb 23, 2008 12:42 am
[quote='TrackerCasey']I know in MI the first one has to be a 5th wheel type[/quote]
I think it is the same story just about everywhere. I used to tow a small trailer or sometimes a boat behind my 5th wheel and never had a problem. Everytime I have ever seen it done, has been behind a 5th wheel. Im not sure about Ohio, but in Florida there is also a length restriction based on your driver license classification.
Jim
D. Marks wrote:
The only time I hug trees is while I'm carring them out of the way.
PostPosted: Sat Feb 23, 2008 1:20 am
In Ky you can pull tandems at a max of 28' each I pull my camper and buggy alot together works good the overhang on the camper (behind the axles)puts the buggy on the outside of a turn so the buggy follows the same trac as the camper when you turn backing is a little tricky !
It is easy to be brave from a safe distance
PostPosted: Sat Feb 23, 2008 7:06 am
I run double tags in Tn. There is not a problem in Tn-- but the font has to have brakes and cant excede weight capacities of truck or lotal length of ?. I pull 2 16'tags behind a 99 gmc Yukon w/ buggies and am right at limit on weight.
I would go to DMV of the state you are in [or plan on going thru] and get all cleared up befor doing. Some states like NC will fry you for crossing there line with things like this!
Mark
High speed
Low drag
Teflon coated
And ready for action!
PostPosted: Sat Feb 23, 2008 8:33 am
Hill Climber
I don't know about lenght laws. I work on the highways and see pickups pulling big campers with boats behind them all the time. I know you can pull double. Call your friendly State Patrol post they will help you out.
Harry S. Truman
PostPosted: Sat Feb 23, 2008 12:05 pm
I will have to make some calls. The weight isn't a problem, the truck is rated to pull around 15k pounds. My camper is a lightweight under 5k. The buggy and trailer wouldn't be over 4k. It would be a train thats for sure. I did read about the Michigan law of the first trailer being a 5th wheel. They called it recreational doubles.
PostPosted: Sun Feb 24, 2008 8:51 am
this is from the ohio bmv i was going to pull my buggy trailer (20') and a jet ski trailer (10') bmv say's thats fine as long as your under 65' total length (truck and trailers)
Passenger Car Trailers
Registration: The original owner of any trailer weighing 4,000 lbs. or less and used exclusively for non-commercial purposes shall, upon application for initial registration, obtain and present such evidence of the trailer's weight as the registrar may require.
Brakes: Brakes are required if the trailer has an empty weight of over 2,000 lbs.
Dimensions: Total length: 65 feet; trailer length: 40 feet; width: 102 inches; height: 13.6 feet.
Hitch: When 1 vehicle is towing another vehicle, the drawbar or other connection may not exceed 15 feet from 1 vehicle to the other.
When the connection consists only of a chain, rope, or cable, there shall be displayed upon such connection a white flag or cloth not less than 12 inches square.
In addition to a drawbar or other connection, each trailer and each semitrailer which is not connected to a commercial tractor by means of a 5th wheel shall be coupled with stay chains or cables to the vehicle by which it is being drawn.
Every trailer or semitrailer shall be equipped with a coupling device, which shall be so designed and constructed that the trailer will follow substantially in the path of the vehicle drawing it, without whipping or swerving from side to side.
Lighting: Trailers must carry, either as part of the taillamps or separately, 2 red reflectors.
Trailers must be equipped with at least 1 red taillamp visible from 500 feet to the rear and a white light to illuminate the license plate and render it visible from at least 50 feet from the rear.
Trailers must be equipped with at least 2 stoplights, visible from 500 feet to the rear.
Mirrors: A left rearview mirror is required.
Riding: Riding in a travel trailer or non-self-propelled manufactured home is prohibited. Riding in a pickup camper is permitted.
Speed Limits: 55 mph is the maximum speed for any vehicle or vehicle combination that weighs over 8,000 lbs.
- Sigmund Freud
- Antonio Meloni
PostPosted: Sun Feb 24, 2008 9:44 am
Hill Climber
Sounds like you can do it. I personally wouldn't worry about being a tad over. IF you did get caught it would be a non points violation.
Harry S. Truman
PostPosted: Sun Feb 24, 2008 9:52 am
i dont see a statey out on the side of 71 or 30 measuring either.
PostPosted: Sun Feb 24, 2008 10:10 am
It would be close. The camper and buggy trailer would be over the 40' length and the total lenth may be 2'-3' over, but I would gamble with that. I would only try this a couple times a year. My other idea is to make a ramp that allows me to drive the buggy up into the dump truck. The front wheels would be over the cab but I could winch it up there somehow. I need about a 18' flatbed now, maybe an old rollback!
PostPosted: Sun Feb 24, 2008 8:42 pm
[quote='JeffClay']i dont see a statey out on the side of 71 or 30 measuring either.[/quote]
Its not them you have to worry about. Its DOT that will give you a hard time. And they do carry tapes and scales in their car. Im sure you will be strapping your buggy down good anyway, but make sure its strapped down acording to how they want it done. I would do everything possible to keep them from pulling you over. Most cops and all DOT check your loads when th
Jim
PostPosted: Sun Feb 24, 2008 8:49 pm
Hill Climber
If it's not commercial the Ohio guys don't care what you pull.
Harry S. Truman
PostPosted: Sun Feb 24, 2008 8:55 pm
if we go out of town m.ralston normally pulls my rail then his in a double and we have had no problem not even going to cold spot and them cops down the road from there we heard were real bad.
kevin
Ridin' in a souped up honda is kinda like ridin' the short bus, no matter were ya go someone is lookin' at ya!
PostPosted: Sun Feb 24, 2008 9:23 pm
Before I left my camper at D&K all the time, I had to pull doubles all the time. My bumper pull camper is 33' my truck is a F350 Quad cab, then the buggy. I do not know how long I was but came from GA., through Tenn., then Ky. with no problems. But I know you can have problems with the DOT, if you have DOT numbers on the truck. I do have a US DOT # but never got pulled over. (Lucky) DOT guys can be a$$ h$$$$ if they want to be. I would just play dumb if you get pulled over, and I was told most of the time if it is for recreational use they will not bother you. People pull into D&K all the time with doubles and triples.
Good Luck
PostPosted: Sun Feb 24, 2008 9:27 pm
I was going to pull two also but was concerned about the laws.
PostPosted: Sun Feb 24, 2008 9:35 pm
[quote='k.elliott']if we go out of town m.ralston normally pulls my rail then his in a double and we have had no problem not even going to cold spot and them cops down the road from there we heard were real bad.
kevin[/quote]
Yes those cops your talking about is Westbound U.S. 52 in Hanging Rock, they are so bad, they will pull you over and give a ticket for going 56 in 55 zone. That sucks!!
PostPosted: Sun Feb 24, 2008 10:04 pm
thats weird cause the first time dean invited us down to ride last july we left hanging rock and passed a cop sitting at night and we had double trailers and no tag or lights on either one of the trailers. guess luck was just on our side.
kevin
PostPosted: Sun Feb 24, 2008 10:09 pm
Hill Climber
They may not care about all that. But I set my cruise control at 54 thru hanging rock.
Harry S. Truman
PostPosted: Fri Feb 29, 2008 10:20 pm
I have a Dodge with a 33 ft tag camper and i pull my buggy behind it . I live in Gardendale Al and have pulled it to Summertown Tn with no problem. I am about 75 ft long. I have got some looks but thats all
