It is currently Sun May 03, 2026 3:58 pm
 Post subject: 1500 into a 1641
PostPosted: Sat Jan 26, 2008 2:45 am
I have a 1500 single port b block. Everyone I talked to said you can make them into a dual port motor. They also say the b block is very weak and should not build it any bigger than a 1641, because of the oil passages. I already have a set of dual port heads, and intake, and a carb. Is it worth buying the top end kit and changing it over, or am I peeing in the wind.
I plan on building a stroker motor on down the line when I find a good block. Just want something with a little more power than the 1500 for this season.
PostPosted: Sat Jan 26, 2008 5:24 am
Yes you can convert it over to dual port and yes it would be worth your time. If you already have the heads, intake and carb. you are well on your way. Buy a set of 87mm pistons and do it. You will need to change out 4 of the head studs, the two middle ones on the top row are shorter for the dual port heads. Other than that you should be good to go. I would also boost the compression ratio up while you are at it. You will need to set this anyway when you install the new top end. Set it around 9 to 1 and you will be happy with it.
PostPosted: Sat Jan 26, 2008 1:03 pm
What would be a good cam to run with this set up? I want something with alot of low end power. Plus my buggy is small 90 inch wheelbase, and I am running 29 inch tractor tires if that comes into play.
PostPosted: Sat Jan 26, 2008 3:58 pm
You need a FK89 with 1.5 rockers cromoly pushrods with dual springs .O hold it im sorry wrong motor .Just kidding I have not a clue better leave this one to Roy
 Post subject: Cam
PostPosted: Sat Jan 26, 2008 4:39 pm
An Engle 100 or 110 will work well with this setup. I had a 1641 once with an Engle 110 with a modified Solex and it ran suprisingly well. Just my 2 cents.
Donnie
PostPosted: Sat Jan 26, 2008 6:41 pm
I thought you were just changing the top end?? Ok then, ................ Personally, I would just leave the cam stock. With the bigger pistons and the compression bumped up higher, it will run really sweet with a stock cam. If you insist on installing a cam in it, the choice should be an Engle 100 if you are using stock heads with a single Solex carburetor. If you intend on changing to a better carburetor down the road, you could use an Engle 110. Do not go higher that that though. It will not run as well.
My advice would be not to split the cases and leave the bottom end alone. As long as the crankshaft end play is under 10 thousandths you will be fine. You could slip a new set of rod bearings in it before you install the new top end. That's always a good idea. Save your money for the bigger motor later on down the road.
Roy
PostPosted: Sat Jan 26, 2008 8:09 pm
i'm running a 1500 made to a 1641 110 cam dell 40 stock heads run great for all i got in it.had a progressive carb on it ran good with it to.
PostPosted: Sun Jan 27, 2008 12:41 am
Thanks for the help Roy. It is greatly appreciated.
PostPosted: Tue Jan 29, 2008 5:35 pm
we have done this swap before, stock heads, 87mm pistons, holley bugspray. didnt change any studs though like roy said, probably shouldve. not my motor though, but ran/runs great.
PostPosted: Wed Jan 30, 2008 4:39 pm
i also did this with a single port had all the parts i needed to put a dual port together i converted it over put it in another buggy and sold it the kid hasnt had any troubles with it
PostPosted: Wed Jan 30, 2008 5:10 pm
ok ok no one liked the FK89 joke darn this is a hard crowd
PostPosted: Wed Jan 30, 2008 5:49 pm
:lol: :lol:
PostPosted: Wed Jan 30, 2008 6:40 pm
[quote='rockrockets1']ok ok no one liked the FK89 joke darn this is a hard crowd[/quote]
i was like what the hell is he ta lking about, then seen that it was only a joke, haha.
