It is currently Sat May 02, 2026 7:48 pm
 Post subject: Side by side coilovers
PostPosted: Thu Jun 11, 2015 1:09 pm
What is everyone's opinion on using these for front suspension? Thinkin about getting Rzr xp4 1000 front shocks
PostPosted: Thu Jun 11, 2015 5:12 pm
Most front ends are designed to use a 10" stroke shock so that should be the first thing to think of. Next how similar is your front end weight as compared to a side by side? What works on a SxS probably won't work so well on a buggy. Kinda like putting a street car steering on a buggy, they'll work, for about 20 min.
PostPosted: Thu Jun 11, 2015 6:55 pm
A 4 seater Rzr 1000 weighs 1500 pound. My buggy will be around that when done. The front shocks are 16 inch travel
PostPosted: Fri Jun 12, 2015 9:24 am
there is no way they are 16" stroke shocks. 10" would be huge on a rzr. They may be 8". not sure why you would go this route. just buy some 10" stroke 2" fox or sway away coil-overs.
PostPosted: Fri Jun 12, 2015 7:33 pm
On the Polaris website they list 16" travel for the shocks.
PostPosted: Fri Jun 12, 2015 11:47 pm
Since I'm building my ecotech I'll Chime in here...
most razors are featuring fox shocks.
Which you can get at about the same price as stock rzr shocks which suck btw!
THE Nicest Set Of shocks that I have seen on a rzr are the walker evans...
Yes they are a little pricey but the make for a good ride on a razor.. however I would not take them off a razor for obvious reasons.. buggies are not rzrs
But I do like there rideablity.. LUCKILY they make more then shocks for razors believe it or not!
I called them yesterday for a quote they have all sorts of types of shocks.
All the way up to 18 inchs of travel. They have a website to. I told the representative guy whom I was talking too that I was using this on a rail buggy and he asked all the perameters of what I wanted.
and he told me he had plenty of options for what I wanted.
Of course they aren't as cheap as fox shocks but they are 100% American made.
Probably just going to go with fox shocks for now because this build is getting expensive so I'm going to take the not so cheap but not to expensive route.
PostPosted: Sat Jun 13, 2015 9:12 am
What does Psycho Alpha think of the wildcat coilovers on his buggy
PostPosted: Mon Jun 15, 2015 9:06 am
the rzr may have 16" of travel, but may only have a 8" stroke shock. your confusing the words travel and stroke.
PostPosted: Mon Jun 15, 2015 9:49 am
Ok. the rear shocks on a Rzr would probably have a 10" stroke since they have a 18" travel then
PostPosted: Mon Jun 15, 2015 4:16 pm
I love them. My front are 8" stroke and I believe I have about 17" of travel. I have around $600 in the 4 walker evens "take offs" coilovers on my buggy. I did have too change rear spring rate.
PostPosted: Sat Jul 18, 2015 8:57 pm
Plenty of racers with 2200-2400lb buggies over here running the SXS shocks from walker evans and fox - they're better made, more adjustable and lighter than the normal versions.
PostPosted: Sat Jul 18, 2015 11:48 pm
Everybody seems to think they won't last. For trail riding and occasional hillclimb I think they would work
PostPosted: Sun Jul 19, 2015 7:03 pm
Been beating mine for year and a half :)
PostPosted: Sun Jul 19, 2015 8:16 pm
And beat it he does lol! :shock:
PostPosted: Tue Jul 21, 2015 4:57 am
I saw you puttin the cat through it paces in the 4th :)
