It is currently Sun May 03, 2026 2:00 pm
Post new topic Reply to topic  [ 310 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10, 11 ... 13  Next
PostPosted: Mon Dec 01, 2014 11:03 pm
riverar321 wrote:
If the old guys beetle was complete, that would be the least expensive route. Buy the beetle ( if the price is right) and put all it's parts on there. I'd just recommend a three rib bus and disc brakes later. You can have a lot of cheap fun with a 1600 and a 3 rib.
Ok, no not complete, but could probably get rear torsion and front end, but also have a buggy shop near my house. engine doesnt run, but i really like the idea of ecotec since im looking for a lot of power.
PostPosted: Mon Dec 01, 2014 11:11 pm
Southern Buggys / WB Sponsor
Trusses are both sides bottom to top. Those back two braces from the bottom of the frame to the top. If you will post or pm me your email I will post several frames I have built and you can look at them for a general idea.
PostPosted: Mon Dec 01, 2014 11:12 pm
william_cool123@hotmail.com
Thank you
PostPosted: Mon Dec 01, 2014 11:15 pm
I better clarify top for you. I should have said top side rail. Not the top of the whole buggy
PostPosted: Mon Dec 01, 2014 11:34 pm
I am still confused, i will try to find pics of how to install it on the internet.
Thanks
Sent from my Nexus 5 using Tapatalk
PostPosted: Mon Dec 01, 2014 11:35 pm
Im also seeking high ground clearance
PostPosted: Tue Dec 02, 2014 12:00 am
Hope those help, i don't really do build pics but customers like to see progress occasionally. These were some of the better pics of where and or how the rear torsion was located.
PostPosted: Tue Dec 02, 2014 8:50 am
That looks like the old short course/stadium car frame. I know they had a fiberglass body for that too!
PostPosted: Tue Dec 02, 2014 8:51 am
Yea its a short course frame :)
Alright thanks
PostPosted: Tue Dec 02, 2014 11:15 am
Will the torsion tube come in this space?
And i weld it there in place?
Thank you guys
PostPosted: Tue Dec 02, 2014 11:32 am
Yes. sit it on top of the 1-1/2" tube on the bottom and push it up tight under the 45* tube then gusset it all together!
PostPosted: Tue Dec 02, 2014 11:37 am
Ok good, i wasnt so sure ahha. now im gonna go hunting for pieces, and for tailing arms, 2x3 or 3x3? im looking for the highest ground clearance and will most probably putting a eco tec 2.2 engine.
Thank you a lot :)
PostPosted: Tue Dec 02, 2014 1:00 pm
2x3 if you wanna run bus CV and bus shafts, they will work but can not handle as much angel as 930 Porsche CV's but with your budget I don't think you'll have the money for 930's. If you want 3x3 you will have to buy aftermarket shafts and can get a little pricy, I run bus cv's they work OK, I have broke a handful of them this year and it sucks but it is better to break a CV than your tranny so a weak link is not always bad
PostPosted: Tue Dec 02, 2014 1:23 pm
Yea, i looked online and they were 500$ for the pair (930), will the bus shafts be good for a eco tec? i will go look, theres a little buggy shop near my house, i will ask him if he has a torsion tube for my frame, im a better with a bus torsion or car? dont really know the difference thanks!
PostPosted: Tue Dec 02, 2014 1:24 pm
Car torsion, bus shafts are fine, just keep a spare setup with u
PostPosted: Tue Dec 02, 2014 1:35 pm
Good! thanks:)
PostPosted: Tue Dec 02, 2014 4:45 pm
if you don't have any cv joints, I would go 930 for sure! Bus only makes sense to me if you already have them. price it out, not a big difference in $.
PostPosted: Tue Dec 02, 2014 5:21 pm
everyone says 930s are overkill...but, guess what I haven't had to mess with in 4 years, and get mass travel with no worries.
PostPosted: Tue Dec 02, 2014 5:30 pm
Agreed !
Plus more angle on the cv =more ground clearance
If your gona do it do it right buy good parts.
Like I said before parting one out almost always ends up costing way more :!::!:
If you cant fix it with a hammer it aint worth fixin!!!!
PostPosted: Tue Dec 02, 2014 5:55 pm
I made that same mistake when I built my first buggy. I bought type2 stub axles, type 2 CV joints and type2 axles only to realize later that a complete 930 setup would have only cost me a few more dollars.
To change it later will require you to replace all of the components
PostPosted: Tue Dec 02, 2014 6:00 pm
ok cool, no, right now i only have the frame so i guess i can go for the 930 cvs.
i also went to my buggy shop, he is going to give me a price for the front axle beam with king pin and torsion IRS rear.
Thanks guys!
PostPosted: Tue Dec 02, 2014 6:54 pm
930s 3x3s 3800 airbags from airbaggit.com torsion eliminators Image
PostPosted: Tue Dec 02, 2014 6:55 pm
custom torsion with bracesImage
PostPosted: Tue Dec 02, 2014 6:56 pm
shock and limiter strap mountsImage
PostPosted: Tue Dec 02, 2014 6:58 pm
the 2 bolts with nylocks eliminate the old style adjusters oImagen king pin
Users browsing this forum: No registered users and 5 guests
