It is currently Mon May 04, 2026 6:31 am
PostPosted: Thu Jan 17, 2008 7:15 pm
Hi guys,
I have some questions about converting my buggy to chain drive. This does not mean that the buggy will be chain drive. I do not want to cause any controversy about this subject. Please bear with me. I am just looking for answers to make a decision. I have used the search feature as part of my research. I have not found the answers that I have been looking for using the search feature. Any help with finding information is welcomed.
The biggest question would be cost. How much to convert over ? How many custom parts ? Is the chain from a motorcycle ? Are the sprockets custom ? More questions will come later.
All remarks are welcomed,
Thank you for any help,
PostPosted: Thu Jan 17, 2008 7:35 pm
You need to talk to the head cheez "curt" his dad invented the chaindrive.I do know the chain is probably 3 times bigger than a motorcycle chain.I wouldnt think it would be cheap at all to convert a buggy over to chaindrive.
aaron
PostPosted: Thu Jan 17, 2008 7:46 pm
A little info to ponder on till Curt or Rock or others chip in is that they run a #80 roller chain. The sprockets run about a dollar a tooth. Them guys run somewhere around 30 or so tooth on the trailing end and at least a 12 tooth on the leading end. :?
PostPosted: Thu Jan 17, 2008 7:47 pm
yes contact curt
PostPosted: Thu Jan 17, 2008 7:49 pm
Talk to firebug he is doing the same thing.
PostPosted: Thu Jan 17, 2008 8:21 pm
I wouldn't think it would cost a whole lot to convert to the chain drive itself, but to maximize the addition of the chaindrive the entire suspension setup itself would have to change. The chaindrive looks to be a seperate bearing carier that will accept a short cv driven axle from the transaxle on one side and a sprocket on the other. This upper sprocket would then connect via chain to the lower bearing carrier. The advantage to me seems the cv driven axle is at very little or no angle at ride height allowing for a lot more travel up or down without the cv's binding. If you can fabricate your own parts most everything on a buggy is within a reasonable price. The cost of steel, welding wire and a couple beers will accomplish a lot. Chains and sprockets are used so widely in industrial equipment I would think they would be the cheapest parts. I'm not biased to either one but I do like thinking out of the box and if it works for you go with it. Curt can help you through it.
PostPosted: Thu Jan 17, 2008 8:23 pm
The one I'm doing is kinda off the wall. It has only a few of the advantages of the real chaindrives. It is still in the R&D stage of development. I expect a prototype to be ready in a couple of months. Basically I am going to gain only about a foot in wheelbase and end up with a final ratio with 6 rib (456) of about 542. Really I'm just foolin around with some old ideas. There are similar cd arms out there. These things are gonna be heavy (blasphemy in ky talk). It's obvious that I am just tinkering and I will keep my old arms just in case. :wink:
PostPosted: Thu Jan 17, 2008 8:33 pm
There ain't a damn thing wrong with tinkering. You go man.
PostPosted: Thu Jan 17, 2008 10:48 pm
This information is helping out. I was not sure about the motorcycle chain working out. I thought the chain would have to be industrial grade. I was glad that was pointed out. The big plus for running a chain drive I would think is, that you could run any engine and transaxle combination. The drivetrain from a front wheel drive could help keep the cost down of building a buggy.
Thanks men for the info. Please keep the information coming. Everything can help.
PostPosted: Thu Jan 17, 2008 10:56 pm
be a pioneer :wink:
PostPosted: Thu Jan 17, 2008 11:02 pm
Hill Climber
Keep watching and I am sure some of the chaindrive guys will help you out. I think this is something you are going to start seeing more often.
Dean
Harry S. Truman
PostPosted: Thu Jan 17, 2008 11:34 pm
The two biggest advantages I see are easily changed gear ratios and extremely long travel suspension. The ratio change is nothing more than changing a sprocket the way a lot of people do on dirt bikes.
PostPosted: Thu Jan 17, 2008 11:45 pm
once you get the combo right you never have to chang .The reason I built mine was I was tired of working on my buggy all the time I could have built a load of CD for what I spent on 930 and tranys
PostPosted: Fri Jan 18, 2008 6:15 am
good to see you on here al, i wish i could help you out more here but i am pretty ignorant to the subject. these guys will steer you in the right direction, though!
PostPosted: Fri Jan 18, 2008 12:23 pm
yea what he said :lol:
PostPosted: Fri Jan 18, 2008 2:34 pm
My next buggy will most likely be a chain drive. :wink:
PostPosted: Fri Jan 18, 2008 7:09 pm
Hurry up and get the bolt on CD done. This might be perfect for my 4x4 buggy if it'll bolt on to a beetle style torsion.
PostPosted: Fri Jan 18, 2008 10:11 pm
Hi Jeff, thanks for turning me on to the web site. It has been a big help.
I appreciate all of the comments and answers from everyone. I have more questions again. Here goes. Is there any brand of sprockets that people perfer to use ? What style of sprockets ? Are the sprockets modified ? I assume the sprockets will be stock. Is this the right assumption ? The custom parts will be the trailing arms and maybe the half shafts and any brackets. Am I on the right track ?
Thanks again for the help,
PostPosted: Fri Jan 18, 2008 10:17 pm
yes the arms are your bigest thing you have to bend them to match the other CD components .sprockets are just ind you can get at local farm store but the better the chain the better off you are.there is a good bit of machine work in the system
PostPosted: Fri Jan 18, 2008 10:44 pm
Here's a couple of links for sprockets and info;
http://www.ablproducts.com/sprockets.htm
http://www.surpluscenter.com/sort.asp?U ... yword=PH80
PostPosted: Sat Jan 19, 2008 4:12 pm
Anybody want to claim this?
[Image
PostPosted: Sun Jan 20, 2008 8:54 pm
Firebug, Thanks for the links. They can be a big help. Your picture does not show up or I can't see it on my computer.
PostPosted: Sun Jan 20, 2008 9:14 pm
Thats weird, It showed up at work and then not at home,,but I redid it,,,,
PostPosted: Sun Jan 20, 2008 11:26 pm
Somebody should wash that nasty thing
PostPosted: Mon Jan 21, 2008 12:46 am
I believe that I know who's that one is. Was taking when we were about to hit the trails I believe.
The Wild Kids
