It is currently Sat May 02, 2026 4:09 pm
Post new topic Reply to topic  [ 42 posts ]  Go to page Previous  1, 2
PostPosted: Fri Nov 14, 2014 5:07 pm
I'm running 3/8"
PostPosted: Fri Nov 14, 2014 5:14 pm
Isn't stock rotors 3/8 ??
PostPosted: Fri Nov 14, 2014 6:09 pm
I got the Empi rotors
PostPosted: Fri Nov 14, 2014 6:55 pm
Gotta love China shit
PostPosted: Sat Nov 15, 2014 10:12 am
That's what happens when the bolts back off and get loose.
PostPosted: Sat Nov 15, 2014 11:15 am
Nope they were good and tight, i even had red lock tight on them too . I'm guessing cheap metal or possible I hit it on something , but I don't see any scar marks on it so I'm leaning to cheap ...
PostPosted: Sun Nov 16, 2014 10:43 am
Those are just cheap junk, I've busted a handful like that alone. Start a pile if thise are what your using lol
PostPosted: Mon Nov 24, 2014 9:08 am
Ok guys got the calipers now the question is what rubber lines did you use they float so obviously require rubber line.
thanks
PostPosted: Mon Nov 24, 2014 12:34 pm
I just threaded a aluminum 1/8"npt x -3 fitting into the caliper and got some -3 stainless braided lines.
PostPosted: Mon Nov 24, 2014 1:14 pm
I used what should go on the car with that caliper
PostPosted: Mon Nov 24, 2014 1:37 pm
That caliper uses banjo fittings. I did not use them. I used steel lines. There's enough flex for them to work.
PostPosted: Mon Nov 24, 2014 2:07 pm
It was just easier for me to us commonly available -3 lines and fittings.
PostPosted: Mon Nov 24, 2014 7:12 pm
Thanks guys appreciate the help
PostPosted: Fri Jan 02, 2015 5:11 pm
New brake calipers work great
IImage
"Just pin it ! she'll go!"
PostPosted: Fri Jan 02, 2015 5:26 pm
Did you make bracket?
PostPosted: Fri Jan 02, 2015 7:54 pm
Yup
PostPosted: Fri Jan 02, 2015 11:35 pm
Lug nuts. That's a condition us old men have. :lol: The caliper bolts are just to keep the caliper straight. The real stopping force should be applied to a lump of steel on the trailing arm up against the caliper. 8) Look at how they are mounted on a car. They never break on a car , right!
