It is currently Sun May 03, 2026 12:59 am
PostPosted: Wed Mar 12, 2014 1:39 am
600 for a 6 rib, 300 for super diff, and a ton for weddle gears , paying to get it done, lets hear your thoughts :mrgreen:http://www.thesamba.com/vw/classifieds/ ... id=1610870
PostPosted: Wed Mar 12, 2014 6:26 am
hmmmmm dave 600 fir the trans 300 for a diff and dad gave the weddle set :lol: :lol:
PostPosted: Wed Mar 12, 2014 7:36 am
Ive got the same ratios and almost that much money in mine but stock 3 and 4 gear stack.
PostPosted: Wed Mar 12, 2014 8:17 am
i mean its prob not a bad price if you was doing one cause the gearsets are like 895 a pc times 2 plus 900 for trans and diff and having somebody put setting it up. i say its worth 2500 but im just guessing
PostPosted: Wed Mar 12, 2014 8:20 am
and looks like the vanago which has the stronger rev gear that is a plus so i would say 2500 if it is what he says it is
PostPosted: Wed Mar 12, 2014 8:34 am
I run a 311 first gear 236 2 gear Dave .So yeah a 344 first would be a good set up kinda wish i would have went that way for the trail riding part.....But for the hill climbing watch out :mrgreen:
PostPosted: Wed Mar 12, 2014 10:38 am
Go narrow baby chains and you can put a stock beetle in it.
PostPosted: Wed Mar 12, 2014 5:56 pm
This is an (091) and not the transmission that has the larger reverse. If it is a nose cone shift it has the regular reverse, you have to go side shift for the larger one (094).
PostPosted: Wed Mar 12, 2014 6:54 pm
I have a the vanagon nose cone side shift , they can be converted to reg. Nose shift & have the big reverse , the case at weddle Is 247.00 with the thick ribs , Chuck converted mine over !
The side shift in the case cannot be I don't think , I think you will lose reverse , right ?
PostPosted: Wed Mar 12, 2014 9:30 pm
I HAVE A NICE NOSE SIDE SHIFT NEVER IN A BUGGY FER $450. NOT CORRODED, TURNS FINE WITH 2 SPYDER DIFF.
PostPosted: Thu Mar 13, 2014 12:05 am
so what is the deal with the ribs that get fatter toward the center of the trans? just a stronger case? or do they have the stronger reverse gear as well? i have a nose cone shift with the ribs that get fatter toward the center that im planning on a super diff. behind an ecotech 2.4. we all trail ride, but ill climb about any hill anyone else will. and passat why do you say 2 spider diff? that is the stock one correct? cause a super has 4?
PostPosted: Thu Mar 13, 2014 6:41 am
Yes, it is the stock 2 spyder diff. Here in the U.S. a 4 spyder came in '83.5 to '85 if it was special ordered. For example towing package, or camper. But all 85.5 and up have 4 spyders and there trans code is located under the drivers side lower corner will read ACW. So basicly 83.5 and up have the BIG gears. But I'd bust 1 a year with my w/c because any case would flex or even crack between the bell housing gasket and the lower right c/v threaded cup. Heavy motors and frame with tall tires, something will have to give. So I went baby chains... Problem solved..lol
PostPosted: Thu Mar 13, 2014 12:35 pm
You cannot convert a true side shift (with the strong reverse) to a nose shift. You can convert a nosecone side shift to a nose shift, but reverse wont be any stronger than a normal nose shift.
PostPosted: Thu Mar 13, 2014 3:50 pm
I don't climb in reverse , so it don't really matter does it ;)
