It is currently Sat May 02, 2026 5:20 pm
 Post subject: fix bent trailing arm
PostPosted: Thu Jan 02, 2014 2:56 pm
need to know best way to fix a slightly bent trailing arm....its a 3x3 appletree arm, one square tube and 2 round....not too bad,yet but it a little out between spring plate mount and hub.....can i heat it and cum along it,then brace it or??????Image
PostPosted: Thu Jan 02, 2014 3:10 pm
take a high speed cutter and put a slit in the bent parts or cut in 2. Straighten out the trailing arm then reweld.
PostPosted: Thu Jan 02, 2014 4:50 pm
I don't think having sex with it will help..lol
PostPosted: Thu Jan 02, 2014 5:44 pm
Is it a little bent like mine was or just a little ...E Just put boxed on it and be done with it
PostPosted: Thu Jan 02, 2014 8:16 pm
just a little bent...can defenetly be straightened out and braced
PostPosted: Fri Jan 03, 2014 2:00 am
let me check my sock and look at it!it was that cat you went sideways over at horseshoe :mrgreen:
PostPosted: Fri Jan 03, 2014 11:18 am
yeah and he didnt even offer to straighten it out lol!
