It is currently Sat May 02, 2026 5:17 pm
PostPosted: Sun Nov 24, 2013 5:11 pm
Does any one know how to dry sump the subie 2.5
PostPosted: Sun Nov 24, 2013 6:55 pm
Odyknuck
PostPosted: Sun Nov 24, 2013 8:01 pm
Hey darrel rather than try and explain how I did mine here go to my blog . It shows a lot of pics and explanations along the way. Here is the link:
http://www.woodsbuggy.com/index.php?opt ... =33&t=6013
After reviewing that and you have additional questions feel free to PM me or post here.
PostPosted: Sun Nov 24, 2013 8:28 pm
Man that is a nice buggy ody.. :shock:
PostPosted: Sun Nov 24, 2013 9:13 pm
And I happen to have an billet aluminum dry sump oil pan that fits a 2.5L Subie.
PostPosted: Mon Nov 25, 2013 8:27 am
http://www.drysump.com/Subaru.htm
PostPosted: Tue Nov 26, 2013 12:06 am
Mike i will for sure keep this in mind...... i'm finding out it's vary hi $$$$$$ to dry sump a subie motor....i think i had about $600 in the vw dry sump tank pump lines and all...And i thought that was hi :shock:
PostPosted: Tue Nov 26, 2013 8:33 am
did you make that mike? :shock:
PostPosted: Tue Nov 26, 2013 1:44 pm
I'm good Jeff, but not THAT good. That pan was designed for experimental aircraft using a Subaru motor. They did a really nice job with the machine work however they messed up with the design. There is only one sump port on the pan, too bad it needs two ports, one for up hill and one for down hill.
I'm, some day, going to add a second port to the flywheel side of the pan to make it usable for off road.
Odyknuck has a similar oil pan on his, it needed modified as well.
PostPosted: Thu Nov 28, 2013 1:26 pm
Darrell look at the Moroso accumulators and Canton accusump. Racebug and I run them. I got my accusump at Drews
