It is currently Sat May 02, 2026 9:45 pm
 Post subject: V-Treads or Terras?
PostPosted: Sun Oct 27, 2013 9:07 pm
I am building a new buggy with a 1915cc engine with a scat cam and dual 44s, in a sandfox frame. I mostly ride in Trevorton and St.Clair and I'm not sure which tires would work better for my setup and for the places I ride. Any information would be helpful.
 Post subject: Re: V-Treads or Terras?
PostPosted: Sun Oct 27, 2013 9:28 pm
Most videos I've seen of treverton, there running paddles.
PostPosted: Sun Oct 27, 2013 9:30 pm
I've seen that too. I was thinking about purchasing a tire cutter and cutting the tires after a trip or two and see if it makes a difference. In the meantime Ill check out paddles and prices.
PostPosted: Sun Oct 27, 2013 10:32 pm
I have a set of each I would get rid of right. They are both used and not pefect but hold air if interested.
PostPosted: Mon Oct 28, 2013 6:12 am
V-treads definately, you may want to venture out to some other locations and terra's just don't hook up like v's do. JMO
PostPosted: Mon Oct 28, 2013 7:02 am
I would agree... V- Treads will give you more options and the ability to go visit other parks.
PostPosted: Mon Oct 28, 2013 7:17 am
hillstomper,
thats where I ride, where u from, I am in Pottstown. heading up 2nd week of NOV to Trev. If you want to be dedicated to the hills say 80% hill play 20% trail go with paddle, if you go 5050 trail go vtread, you can sharpen the vtreads to do some nasty stuff (look around the forums on how to modify) if u got the doh get both. If you ride mostly St. Clair stay vtred. I run interco un modified vtreads with stock 1600 straight propane turbo t25 and even before the turbo and propane I got through everything I pointed at, (with in reason) baby coal hills for me, I also have a buss 2ltr I got for cheap that I am putting in later.
I hope ur close hit me up.. Always lookin for another to ride with.
PostPosted: Mon Oct 28, 2013 7:24 am
never mind where ur from I just looked it up, St. Clair is ur back yard.. HAHAHH A
PostPosted: Mon Oct 28, 2013 11:18 am
Ok thanks for input. Jason108 do u mind posting some pics of the v-treads that u got? I am interested
PostPosted: Mon Oct 28, 2013 2:09 pm
This are the ones I use to just go riding they are bkt v-treads. And I have a set of stones to
PostPosted: Mon Oct 28, 2013 5:08 pm
Now I am considering running a 5 or 6 rib trans along with the 1915cc engine, will the trans and engine have any effects on the v's, traction wise?
PostPosted: Mon Oct 28, 2013 7:06 pm
I'm sorry I have paddles and terra tires I think I have a picture of the tear tires
PostPosted: Mon Oct 28, 2013 7:23 pm
that would be great if u can get a pic. How much for the paddles?
PostPosted: Mon Oct 28, 2013 10:32 pm
Do u want the rims too. They r 16.50 on 18 aluminum rwide 5 have adapter also. Will see what I can do about a picture tomorrow
PostPosted: Tue Oct 29, 2013 10:36 am
Do the terras come with rims too or only the paddles?
PostPosted: Tue Oct 29, 2013 6:58 pm
They are on steel rims I think one is slightly bent though. Look great lol
PostPosted: Tue Oct 29, 2013 8:41 pm
ok cool
PostPosted: Wed Oct 30, 2013 4:26 am
I can text pictures of terras.
