It is currently Sun May 03, 2026 10:49 am
Post new topic Reply to topic  [ 525 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 21  Next
PostPosted: Sun Aug 18, 2013 9:19 pm
The Wild Kids wrote:
Unloaded the buggy out of the trailer. Took everything out of said trailer, then swept it out. Got barefooted and shook the hell out of the gallon paint can. Poured it out in the roller pan and got to painting the inside of the trailer. WHITE!!!!! Really brightens up the trailer so at night it will be bright enough to see if I have to work on the buggy out at the camp sites or at a buggy ride.
Debating on what to do to the floor, either LineX or buy the rhino and do it myself. That or diamond plate the floor!
I had Line-x spray the rear gate and the first 8'-0 of the floor it would have cost $600.00 but I bartered 1000 rounds of 9MM that I loaded so it cost me about $200.00 it is real nice just hose it out.
PostPosted: Mon Aug 19, 2013 12:54 am
I had my truck sprayed with lone x and it cost $530 for the whole bed. Was thinking 14 feet in and the carpet the rest with that out door carpet you see in truck beds.
PostPosted: Wed Aug 21, 2013 11:00 pm
I added the other bar to my head/pushrod protectors that would keep it from bending upward. Changed spark plugs to hotter ones and adjusted one carb. Getting it ready to Ride Royal Blue this Saturday (hopefully).
PostPosted: Wed Aug 21, 2013 11:34 pm
Took the brother in law for a ride!
He is hooked now.
PostPosted: Thu Aug 22, 2013 1:22 am
I put a new alt and v reg in it. Done. Tomorrow load it on the trailer and pack up to be ready to roll out Friday morning to Bellas gig. :D
PostPosted: Thu Aug 22, 2013 10:20 am
Spent a few hours debating on where to mount my oil cooler. Any ideas? Then I figured out my pulley is a power pulley so I probably don't even need an oil cooler.
PostPosted: Thu Aug 22, 2013 1:12 pm
drilled and taped remote oil filter for a oil temp sensor.
PostPosted: Thu Aug 22, 2013 9:14 pm
I picked up a new buggy today. 1915 with a type 3 turbo and 6 rib trans. 16.5 wide paddles on the back 3 ribs on the front. Thing rips. Big jump from a worn out 1600 lol
PostPosted: Thu Aug 22, 2013 9:20 pm
I peeked down under the pavilion to see if it was getting wet from the rain thinking man I can't wait for next weekend still undecided where I will be riding wv or wellsville that is the big question
PostPosted: Thu Aug 22, 2013 10:06 pm
Aired the tires up on my 2 seater and fixed the front shock tower. Started taking the motor off my 1 seater.
PostPosted: Thu Aug 22, 2013 11:08 pm
Got the 4 seater ready for Saturday....
I got this...
"I got this..."
PostPosted: Sat Aug 24, 2013 6:05 am
Went over the new buggy today. Fixed so shabby wiring and put a tach in. Got some time to ride it and found I couldn't reach the pedals lol. Moved the seat front and adjusted the harness. Cant wait to get it up to do some climbing. Will try to post a pic soon. :mrgreen: :mrgreen:
PostPosted: Sat Aug 24, 2013 6:06 am
PostPosted: Sat Aug 24, 2013 12:26 pm
superdiff for the 091, 2332 mystic performance motor from aaron creech, new used beam (well 2 or 3 that made one good one), new brakes, reinforced cage (all but x-brace behind seats), new pads, new tie rods, new oil cooler, new brake lights, 4 led headlights (3 now that i smashed one in a fit of anger lol) and new tach.... and the ability to give it a tiny bit of pedal and they break loose
if it aint broke don't fix it
PostPosted: Sat Aug 24, 2013 3:27 pm
Drove it from the basement to the shop. Cleaned air filters and put covers on them. Drove it back to the basement. THE END
PostPosted: Tue Aug 27, 2013 4:53 pm
I unloaded and washed it from the Ride Royal Blue trip .
PostPosted: Tue Aug 27, 2013 7:01 pm
Loaded up Heading Out Tomorrow for a 6 day ride
PostPosted: Tue Aug 27, 2013 8:03 pm
Checked timing and adjusted idle. Purrs like a kitten now. All ready to ride Labor Day. Can't wait :mrgreen:
PostPosted: Tue Aug 27, 2013 10:25 pm
WOW. topgun...a 6 day ride :shock: .You lucky dog. Where are you going?
PostPosted: Tue Aug 27, 2013 10:37 pm
Well we're starting out at Choccolloco Mtn. Then we're taking off to Grey Rock
PostPosted: Wed Aug 28, 2013 3:27 am
Took it out. Took the baby girl for a put-put. Put it away:) put trans strap on the new buggy and the rear wheels
PostPosted: Fri Aug 30, 2013 11:15 am
well installed a push in sand seal and new pulley, new belt. some new push rod tubes. (only the one that were leaking) new valve cover gaskets and adjusted valves last night. this afternoon i will put a new O ring on Dizzy and re-adjust the timing. and make sure she doesn't leak!! LOL!!! and then i need to adjust the rear torsion.
so it will set up a little higher! ( Friday night riding at Rush wasn't fun after i got a case of the Swamp arse after going through a deep water hole! LOL!! ) then i have some drop spindles for the front that i bought off a guy here on woods buggy that i may finally try to install! this week end.
PostPosted: Fri Aug 30, 2013 7:48 pm
I thought VW engines were supposed to leak to indicate that there was oil in the case!!!
Swamp arse now thats funny!!! been there though
PostPosted: Fri Aug 30, 2013 9:39 pm
I got the buggy loaded on the trailer gased up and ready to go to Biscuit Mtn in the morning. Ready to finally ride again. Last time I really rode some where was back in 2009 at Windrock.
PostPosted: Sun Sep 01, 2013 2:33 pm
Pulling the carbs off to clean and rebuild today. After trying to ride yesterday at Biscuit the carbs pissed me off so its time to inspect clean and rebuild them.
Flipper
The Wild Kids
