It is currently Sat May 02, 2026 11:20 pm
 Post subject: need help with flywheel
PostPosted: Wed Aug 21, 2013 9:14 pm
With 4 thou. Endplay motor won't turn over you can move flywheel back and fourth about half inch and its a solid hit both way. With 7 thou. It turns over. Any ideas ? Never ran into this before
PostPosted: Wed Aug 21, 2013 9:23 pm
Sounds like the crank is hitting something. I have seen stock stroke counterweight cranks hit at the center main web.
PostPosted: Wed Aug 21, 2013 9:31 pm
Its a 2276
PostPosted: Wed Aug 21, 2013 9:50 pm
Its a running motor just putting new flywheel on it.
PostPosted: Wed Aug 21, 2013 9:59 pm
just a thought. If it is too tite then the thrust bearing is so tite against the flywheel that tha bearing is actually moving inside the block. But the dowel peg is the only thing stopping the flywheel now. A 1/16 of an inch at the peg could mean a 1/2 at the flywheel. So put it on 10 and be safe. but 1st of all is your dist. drive shaft held down by the dist?
PostPosted: Wed Aug 21, 2013 10:45 pm
Just found it ya thrust bearing. Thanks
PostPosted: Thu Aug 22, 2013 9:58 am
Sounds like it needs to come apart.
