It is currently Mon May 04, 2026 1:04 am
 Post subject: Best Shifter??
PostPosted: Fri Aug 09, 2013 8:36 pm
I'm looking to buy a new shifter. Anyone have a good suggestion
 Post subject: Re: Best Shifter??
PostPosted: Fri Aug 09, 2013 9:13 pm
A new stock shifter is still the best.
PostPosted: Fri Aug 09, 2013 9:14 pm
Southern Buggys / WB Sponsor
X2
PostPosted: Fri Aug 09, 2013 9:38 pm
Are the super shifters any good?
PostPosted: Fri Aug 09, 2013 9:39 pm
Thanks guys
PostPosted: Fri Aug 09, 2013 11:10 pm
The old origial hurst not the new emi knockoffs . Gene berg. And stock .
PostPosted: Sat Aug 10, 2013 10:03 am
Scat drag fast
PostPosted: Sat Aug 10, 2013 10:56 am
I had a super shifter and it was terrible. I DO NOT recommend a Super Shifter. Mine was made by Empi, the Jamar ones might work better. Even if it shifted better, it was difficult to get into reverse with one hand.
PostPosted: Sat Aug 10, 2013 11:58 am
NRIbuggys wrote:
Scat drag fast
X2, if your speed shifting or just trail riding mine does great , once you get used to the
Tight shift pattern you should like a whole lot , but the stock shifter is more forgiven than any of the rest I suppose !
PostPosted: Sat Aug 10, 2013 12:24 pm
scat dragfast
PostPosted: Sat Aug 10, 2013 2:47 pm
I like the super shifter it works great and feels good only downfall is reverse but its easy once you get use to it
PostPosted: Sun Aug 11, 2013 12:05 am
X2 on Hurst it is hard to beat the quality and durability of a Hurst shifter.
Kenric
PostPosted: Tue Aug 13, 2013 9:04 pm
Broken then all, my favorite is a Scat drag fast.
PostPosted: Tue Aug 13, 2013 9:22 pm
Its hard to beat stock for the money . I have a drag fast and like it . My wifes buggy has a empi shifter in it and I had rather reach back and shift it with vise grips as run a empi shifter . I got to replace hers !
PostPosted: Wed Aug 14, 2013 3:23 am
I like my t handle shifer more than any I have had its smooth and works good and tight not sloppy
