It is currently Sat May 02, 2026 5:47 pm
 Post subject: NO SECOND
PostPosted: Fri Jun 28, 2013 7:47 pm
Just driving down the road and went from first to second and nothing so i went to third its there and so is fourth and reverse. What the heck............no weird sounds and no second.
 Post subject: Re: NO SECOND
PostPosted: Fri Jun 28, 2013 10:46 pm
simple but is linkage adjusted right sometimes that will do it it there was no grind or pop? or is the coupler wore out ? food for thought
*subiepower*
PostPosted: Fri Jun 28, 2013 11:34 pm
yes. and put some tie wire thru that set screw bolt.
PostPosted: Sat Jun 29, 2013 11:36 am
linkage for me when i had this problem... shifter can move a little on mine and that what did it to me...
if it aint broke don't fix it
PostPosted: Sun Jun 30, 2013 10:52 am
I had a similar problem M-Day, but it was 1st gear. After opening the transaxle, I found the 1-2 shift fork moved toward 2nd and just needed re-adjusted.
PostPosted: Tue Jul 09, 2013 10:09 pm
Ok it sounds like everyone thinks the linkage needs to be adjusted. So how much trouble is it to do. or is this something i need to take to someone.
PostPosted: Tue Jul 09, 2013 10:23 pm
take the whole shifter off the trans and shift with vice grips to rule out couplers and shifters etc. But, GuyP is probably right.
PostPosted: Wed Jul 10, 2013 10:56 pm
put the trans in reverse and then put your shifter in reverse and tighten everything down.. it SHOULD fall into all the gears, given nothing is wrong with the trans itself
LEGALIZE BLUEGRASS!!!
Save a tree... eat a Beaver
