It is currently Sat May 02, 2026 4:38 pm
 Post subject: 2 piece rotors?
PostPosted: Sun Apr 07, 2013 8:55 pm
If I understood what i've read on here, I need to find a set of type 3 drive hubs and cut down to fit inside the 72-76 porsche 914 rotors, is this right? If so is there anything else i need to get or find? does anyone know where to find a set of type 3 drive hubs in north alabama? thanks ahead for the help
 Post subject: Re: 2 piece rotors?
PostPosted: Sun Apr 07, 2013 10:01 pm
http://www.woodsbuggy.com/index.php?opt ... =7&t=14905
PostPosted: Mon Apr 08, 2013 9:14 am
what you think it would cost to ship to alabama? - zip is 35674
PostPosted: Mon Apr 08, 2013 11:52 am
Somewhere around $14.00
PostPosted: Tue Apr 09, 2013 12:01 am
maybe somebody can explain what the difference is between a type 1 and type 3 hub/drum?
my 1st buggy had Porsche rotors and type 1 hubs that had the drum turned off of it. I had one strip the splines out when the nut got loose and I just bolted on a whole type 1 hub/drum and put the buggy on jack stands, then cranked it up in gear an let it idle, then I used a cut off wheel on a side grinder to cut just outside the studs/lugs and when done it looked like it had been machined off and the Porsche rotor went right back on just like the old one :?
PostPosted: Tue Apr 09, 2013 6:13 am
Sweet tech tip.
PostPosted: Tue Apr 09, 2013 9:45 am
so either type 1 or 3 hubs will work as long as they're cut down to fit inside the porsche rotors? I've got a set of type 1's that i can cut down. all the new rotors I've found so far ranges from 75.00 to 85.00 ea. is this about right or does someone know of a cheaper place to buy them. thanks for the help
PostPosted: Tue Apr 09, 2013 12:39 pm
Well thanks a bunch.
PostPosted: Tue Apr 09, 2013 2:05 pm
:cry: :roll: :|
PostPosted: Tue Apr 09, 2013 2:06 pm
:o :cry: :roll: :| or sometimes it is easier just to buy them!!!
PostPosted: Tue Apr 09, 2013 2:41 pm
if it was easy, what fun would that be? :D :lol: ,, if i could find a good one piece that i could afford besides empi, that would be great, anybody got any ideals? money done got tight building a new buggy.. thanks alot guys ahead of time
PostPosted: Wed Apr 10, 2013 3:29 am
not sure what you talking about but I wasn't trying to knock a sale if that's what you mean, if so im sorry but if that was the case I would have just called him seeing as I know him and his brother is a friend of mine and only live about 30 min away
was just and still wandering what/why some folks say use a type hub and what difference was as ive never had any dealings with any type 3 stuff :?
PostPosted: Wed Apr 10, 2013 8:49 am
thanks for the help chris, didnt mean to cause trouble, just needing help since i'm trying to learn, i'm new to building buggies. thanks for all the help from everyone
