It is currently Sun May 03, 2026 1:15 am
 Post subject: tubes in ur tire,s
PostPosted: Wed Jan 02, 2008 9:27 pm
i had a booger come off the rim this weekend. i run bead locks. just wanting to no what u think about running tubes.would it help?
PostPosted: Wed Jan 02, 2008 9:35 pm
I wish I could say I have bead locks but, I do run tubes. I run about 6 psi in 31x15.50 tractors with good success. I've had the bead come off and it ussually puts itself back on, or just put a few more pounds in it to help it out.
PostPosted: Wed Jan 02, 2008 9:40 pm
Hill Climber
Heres what a tube did for me. I rode all day like this.
Harry S. Truman
PostPosted: Wed Jan 02, 2008 10:15 pm
irun tubes in all of mine
PostPosted: Wed Jan 02, 2008 10:40 pm
mixxed emotions on tubes.
i can plug a tire in the woods but patching a tube would be a serious PITA.
PostPosted: Wed Jan 02, 2008 10:43 pm
you can always carry a valve if your tube goes flat just plug the tire and put the valve in. done this many times works well
PostPosted: Wed Jan 02, 2008 10:45 pm
I have tubes in the front and tubeless in the rear. When I did have the firestones I run beadlocks and no tubes. It is all in what you are comfortable in fixing on the trail and have the tools with you I guess.
I am trying to find one of those spark plug pumps like one of the guys I ride with has. Simply screw it in a sparkplug hole and let the engine run to pump it up. Nice to have when you are in the back forty someplace.
The Wild Kids
PostPosted: Wed Jan 02, 2008 10:46 pm
my wife had a flat we took it off broke it down patched the tube and was riding in 20 min it was a 18.5/44/15
all on trail
PostPosted: Wed Jan 02, 2008 10:49 pm
u can take a pump off a car with air ride put a hose and a air chuck works real good CHEAP.
PostPosted: Thu Jan 03, 2008 9:52 am
[quote='The Wild Kids']I am trying to find one of those spark plug pumps like one of the guys I ride with has. Simply screw it in a sparkplug hole and let the engine run to pump it up. Nice to have when you are in the back forty someplace.
The Wild Kids[/quote]
here ya go.
http://www.jcwhitney.com/webapp/wcs/sto ... ogId=10111
PostPosted: Thu Jan 03, 2008 10:02 am
I have never had any luck with tubes on the rear. I've never tried them in the front. Could be my lack of driving skill, I hit every thing in the woods!
Rick
Life is like a jar of Jalapeno's.What you do today,Might Burn Your Ass Tomorrow
PostPosted: Thu Jan 03, 2008 11:38 am
buggyznuts did u try them with bead locks?
PostPosted: Thu Jan 03, 2008 12:01 pm
I ran tubes in all of my tires when i had my cb. The only time I ever had a problem is when I ran bolt tires and a bolt pinched the tube. The rubber tires i ran where 38x11 boggers, usually around 3-4 psi never had any trouble with them. Plus you can carry a spare with you, they fold up pretty small so you can store them anywhere.
PostPosted: Thu Jan 03, 2008 12:16 pm
I run tubeless with my diggers when possible. Used to run tubes and had flats ALOT with about 3-4 psi. But if I have to install tubes now I take the tire off the rim and wash and dry the inside of tire and rim as good as possible. Get all the junk out of there. Then I took an old tube and kinda made a liner around my good tube, and put plenty of baby powder in between tubes and on rim and in tire. Got tubes in a couple of my buggies now and I've had good luck since doing this. Dont know what the powder does, somebody told me to do that and it seems to be helping quite a bit.
PostPosted: Thu Jan 03, 2008 2:10 pm
I've always had beadlocks still had trouble. I ran tubes 2 weekends and had flats both times (4psi) after that I went tubeless and didnt have anymore trouble. I know several guys that run them and like them I guess its like anything else just personal preference
Rick
PostPosted: Thu Jan 03, 2008 6:34 pm
I always use tubes in all 4 tires. Pinch the rears sometimes when I hit something hard but they are worth it in my opinion.
PostPosted: Fri Jan 04, 2008 2:42 am
Wild Kids,,,,check your PM's I sent ya a link for the tire pumps,,,,I have a new 1 I need to put a hose on they work good!
PostPosted: Fri Jan 04, 2008 3:29 am
Thanks I will check it out next.
The Wild Kids
PostPosted: Sat Jan 05, 2008 9:54 am
I run tubes too. I like others take tubless stems and an air compressor with me. I get a flat I pop in stem air it up and go. Its the best of both worlds. Another option is I know you can buy smaller tubes that come with Slime allready in them. I wonder if they are avalable in the sizes we need.
Hmmm! Guess I will have to look into that and get back with ya.
